vtec point
You should be able to feel it, or atleast tell by engine sound. Its at around 4500rpm. Feel Free To Correct Me If I'm Wrong.
wrong.get a CAI or remove the stock airbox from ur intake. u WILL hear the sound
(neptune, I assume u have a bone stock car
[Modified by MikeMAN, 10:46 AM 3/4/2003]
)[Modified by MikeMAN, 10:46 AM 3/4/2003]
Wrong. Not flaming but in a SOHC engine you cnnot tell at all when vtec kicks in. there is no difference in engine sound or g force. Pretty much you an only tell by how fast the rpms fly up.[/QUOTE]
you sure? Cause, i know you cannot feel vtec in a sohc engine, but I do hear a difference in the sound.
you can hear and slightly feel vtec in a Sohc Vtec engine. I have found using my fields vtec controller on my Z6 i can hear it a lot better when i move it higher in the RPM band(its really loud at 6000+ rpms). And i can really hear it in 1st, 3rd and 4th (never hit it in 5th). I have mine at 5000, but i believe the Y8 P2P ecu hits it at 5200, but i could be wrong. btw not to knock anyone but the sohc vtec engines are very capable of making power, they just get kicked around because i wouldn't want an N/A sohc vtec (bolt on's only) in a coupe i would want to swap in a b series because of the torque needed to move the weight of a coupe. In comparison for the money i could spend on putting a b16a in my car, i could put the same money into my Z6 and make it smoke a b series swap without even using forced induction or nitrous. just my .02
[Modified by yebabee, 9:03 AM 3/4/2003]
hahaha yea some say u can n some say you cant. But me, i think i do feel it, and i can definitly hear it. . . mite b cuz dats da only thing i look forward to hahaha
well i could hear it when it was stock as a little high pitched whistle but since i got all my mods(i/h/e, testpipe, gutted) i chouldn't hear the whirr anymore so i put in a vtec activation light that is hooked up to the vtec solonoid so it turns on when vtec kicks in, pretty handy for learning your engine and tranny.
ih8danoles
38
Mar 31, 2003 09:55 PM
