SRR rear sway bar
JDM ITR = 23mm
99-00 SI = 13mm bar
GSR = 14mm bar
[Modified by Beave0101, 9:05 AM 3/6/2003]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beave0101 »</TD></TR><TR><TD CLASS="quote">I believe they switched TO a 23mm bar in 1998.....it used to be a 22.......or was it 21
Correct.
96 spec ITRs had a 22 mm sway bar.
98 spec had the bigger 23 mm.
</TD></TR></TABLE>Correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LonelyDriver02 »</TD></TR><TR><TD CLASS="quote">Does anybody know if the ST sway bar will work with the SRR lca's and tie bar combo? or will it have some sort of clearance problems, this is on a 00 si. Thanks.</TD></TR></TABLE>
The ST sway bar should work with the SRR components just fine.
BLUE EH3
13
Jun 8, 2005 06:18 PM
lowgman
May 11, 2004 11:12 AM
Mr.Rab
Sep 27, 2002 12:18 PM
