SRR rear sway bar
Old 03-03-2003, 12:51 PM
ABTDer's Avatar
Default SRR rear sway bar
does anyone have one of these on their EK/EM? does anyone know how thick it is? how is it compared to a ST rear sway bar? or an ITR? thanks
Old 03-03-2003, 06:05 PM
civic23g's Avatar
Default Re: SRR rear sway bar (Drunk-N-Munky)
It is a 19mm bar i believe. That's all i know about it.
Old 03-03-2003, 06:25 PM
ExospeedAMcrx's Avatar
before I shipped the last one in stock out, I measure also. 19mm
Old 03-05-2003, 11:36 PM
ABTDer's Avatar
Default Re: SRR rear sway bar (exospeedAMcrx)
how thick is the JDM ITR rear sway bar?
Old 03-05-2003, 11:44 PM
fowler!'s Avatar
JDM ITR = 23mm
USDM ITR = 22mm
Old 03-05-2003, 11:58 PM
ABTDer's Avatar
Default Re: SRR rear sway bar (fowler)
how thick is the Si rear sway bar?
Old 03-06-2003, 12:04 AM
Beave0101's Avatar
JDM ITR = 23mm
I believe they switched TO a 23mm bar in 1998.....it used to be a 22.......or was it 21
99-00 SI = 13mm bar
GSR = 14mm bar
[Modified by Beave0101, 9:05 AM 3/6/2003]
Old 07-16-2003, 08:11 AM
LonelyDriver02's Avatar
Default Re: SRR rear sway bar (Beave0101)
Does anybody know if the ST sway bar will work with the SRR lca's and tie bar combo? or will it have some sort of clearance problems, this is on a 00 si. Thanks.
Old 07-16-2003, 08:24 AM
fowler!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beave0101 &raquo;</TD></TR><TR><TD CLASS="quote">I believe they switched TO a 23mm bar in 1998.....it used to be a 22.......or was it 21 </TD></TR></TABLE>
Correct.
96 spec ITRs had a 22 mm sway bar.
98 spec had the bigger 23 mm.
Old 07-21-2003, 11:02 AM
Perpetual Concepts's Avatar
Default Re: SRR rear sway bar (LonelyDriver02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LonelyDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">Does anybody know if the ST sway bar will work with the SRR lca's and tie bar combo? or will it have some sort of clearance problems, this is on a 00 si. Thanks.</TD></TR></TABLE>
The ST sway bar should work with the SRR components just fine.
mish__
Suspension & Brakes
05-27-2011 09:08 PM
BLUE EH3
13
06-08-2005 06:18 PM
lowgman
05-11-2004 11:12 AM
Mr.Rab
09-27-2002 12:18 PM
Quick Reply: SRR rear sway bar
