b16 im on ls?
b16 im on ls?
i was wonder cuz i heard the b16/itr intake manifold fits on the b18b head is that corect?
now will puting a b16 im on my ls flow better? is so has anyone doen this? will the t/b and all sensors hook up?
thanks for the space
Re: b16 im on ls? (jdmchop)
You got it mixed up. It's the skunk 2 manifold that your referring too. They make the Inake manifold for all the B series heads. And they all look alike! But no the B16 manifold will not fit on the LS head so don't try it. Just get a skunk 2 manifold for your LS head...
Re: b16 im on ls? (xJDM88EF9x)
why would only a skunk2 manifold fit on his LS head......the b16 will fit on it too....and the skunk2 doesnt fit all b-series.....GSR takes a different one. If you put a b16 manifold on your car, make sure it's compatible with your sensors
Re: b16 im on ls? (blueintegra90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 »</TD></TR><TR><TD CLASS="quote">why would only a skunk2 manifold fit on his LS head......the b16 will fit on it too....and the skunk2 doesnt fit all b-series.....GSR takes a different one. If you put a b16 manifold on your car, make sure it's compatible with your sensors</TD></TR></TABLE>
im pretty sure a b16 im will not fit
STFU and get your facts straight!
You can modify a b16 Intake manifold to fit onto a LS head.. since the B16/ITR intake manifold are identical in bolt pattern and people have modified ITR manifolds to bolt up.. but why use a b16 intake manifold even those are restrictive compared to the ITR one...just get an LS and save a headache
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 »</TD></TR><TR><TD CLASS="quote">why would only a skunk2 manifold fit on his LS head......the b16 will fit on it too....and the skunk2 doesnt fit all b-series.....GSR takes a different one. If you put a b16 manifold on your car, make sure it's compatible with your sensors</TD></TR></TABLE>well i'm pretty sure it wont fit cause i have a b20 with ls manifold.. and i had a b16 before .. so it that were the case i would have used the b16 manifold...so in otherwords dont answer questions u dont know **** about.. other people might look at this thread for the same info. so dont confuse the **** out of everyone.. and if anyone wanna buy a b16 obd1 mani.. im me..
Re: b16 im on ls? (tangb2023)
ok now i would like to revise my question.
Has anyone used a itr/b16 oem manifold on there ls head?
please only people with experience actualy doing this mod respond so we can get the facts straight.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop »</TD></TR><TR><TD CLASS="quote">ok now i would like to revise my question.
thanks</TD></TR></TABLE>
you have to cut the end where it bolts up and weld the ls one in its place
