SRR rear sway bar
SRR rear sway bar
does anyone have one of these on their EK/EM? does anyone know how thick it is? how is it compared to a ST rear sway bar? or an ITR? thanks
Re: SRR rear sway bar (fowler)
JDM ITR = 23mm
99-00 SI = 13mm bar
GSR = 14mm bar
[Modified by Beave0101, 9:05 AM 3/6/2003]
Re: SRR rear sway bar (Beave0101)
Does anybody know if the ST sway bar will work with the SRR lca's and tie bar combo? or will it have some sort of clearance problems, this is on a 00 si. Thanks.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beave0101 »</TD></TR><TR><TD CLASS="quote">I believe they switched TO a 23mm bar in 1998.....it used to be a 22.......or was it 21 </TD></TR></TABLE>
Correct.
96 spec ITRs had a 22 mm sway bar.
98 spec had the bigger 23 mm.
Correct.
Re: SRR rear sway bar (LonelyDriver02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LonelyDriver02 »</TD></TR><TR><TD CLASS="quote">Does anybody know if the ST sway bar will work with the SRR lca's and tie bar combo? or will it have some sort of clearance problems, this is on a 00 si. Thanks.</TD></TR></TABLE>
The ST sway bar should work with the SRR components just fine.
BLUE EH3
13
06-08-2005 06:18 PM
lowgman
05-11-2004 11:12 AM
