how can you tell if the cam is tdc
Old Mar 2, 2003 | 01:08 PM
coldfiremx's Avatar
Default how can you tell if the cam is tdc
how can you tell if cam is tdc without pulling off the valve cover?
Old Mar 2, 2003 | 01:16 PM
coldfiremx's Avatar
Default Re: how can you tell if the cam is tdc (coldfiremx)
bump
Old Mar 2, 2003 | 01:17 PM
coldfiremx's Avatar
motor is a d16y7
Old Mar 2, 2003 | 01:38 PM
delslow94's Avatar
you have to pull the valvecover otherwise there are no markings to line up
Old Mar 2, 2003 | 01:49 PM
poison's Avatar
there should be a marking on your cam gear. when the marking is pointed up, your #1 is at TDC.
Old Mar 2, 2003 | 04:52 PM
Foozball26's Avatar
Default Re: how can you tell if the cam is tdc (poison)
get a long extension and pull out the # 1 plugwire and spark plug
put the extension in the hole and then get a 19mm or 17mm socket (motor pending) and ratchet and turn the motor over by hand and when the extension is at the highest point it can go bam TDC.
make sure the cam gear lines are lined up after you do this to make sure you have the cams in properly.
Old Mar 2, 2003 | 05:20 PM
DragII's Avatar
25 Year Member
Default Re: how can you tell if the cam is tdc (foozball-26)
my d16y8 stock cam gear had an arrow, that said "up" on it.
Old Mar 2, 2003 | 05:26 PM
tek_civic's Avatar
Default Re: how can you tell if the cam is tdc (DragII)
make sure your at TDC on the intake step and not the exhaust step when using the description above, the only way i know how to do this is by feeling the pressure build up as you crank the engine, it might say on the sproket though. gl
Old Mar 2, 2003 | 05:45 PM
sshaikh01's Avatar
Take the valve cover off.
Get an extention or two.
Turn your cranck and watch the camgear.
The camgear will have a marking called UP or a arrow.
Make sure its at the top.
and you're set to tear your engine apart.
Old Mar 3, 2003 | 04:57 AM
Foozball26's Avatar
Default Re: how can you tell if the cam is tdc (sshaikh01)
you don't need to take off the valve cover to do the extention trick
sayanything
Dec 21, 2010 06:36 PM
Tatakai
Apr 28, 2007 02:42 PM
crx00
Apr 21, 2006 03:08 PM
slammedcivicsi
Sep 13, 2004 09:54 PM
sabertooth
Jun 18, 2004 08:53 PM
