which up is the correct up for cam gears?
i was adjusting my timing because it was off by a tooth, but now that i look at it im not sure. do i set the "up" arrow on the cam gears in relation to the motor (looking at the top of the head where it meets the valve cover) or in relation to the ground? here's a pic, exhaust cam is UP in relation to the motor, intake is UP in relation to the ground. number 1 piston is like 1* after TDC (the mark on the end of the crank gear and the block)
pics enclosed for you're pleasure.
Re: which up is the correct up for cam gears? (sicones)
the intake is off by a tooth cuz i was tryin to figure out which one was correct lol
thanks for the quick reply!
Old_Honda
01-10-2006 09:19 AM
B_1_8_hatch
03-17-2003 05:53 PM
