Running waaaay to rich! How can I fix this?
Old Feb 28, 2003 | 06:49 PM
CBR600OnTop's Avatar
Default Running waaaay to rich! How can I fix this?
I am getting my 2001 integra gs with a drag III kit tuned tommorow. My idle is really slopy and studders when pushed. I have 440 cc rc injectors, fuel pump, fmu, and an safc. Instead of me buying an adjustable fuel pressure regulator will the safc be able to tune this or should I just go with the fpr. Thanks
Old Feb 28, 2003 | 06:51 PM
b16ahybrid's Avatar
Default Re: Running waaaay to rich! How can I fix this? (TegTuner)
yep you should be able to pull enough fuel to lean it out.an adjustable fpr is only handy to lower your static fp.
Old Feb 28, 2003 | 06:58 PM
Default Re: Running waaaay to rich! How can I fix this? (b16ahybrid)
k. thanks. any other suggestions? Or does anyone have a set up similar to this that has had this done?
Old Feb 28, 2003 | 07:07 PM
B20-T's Avatar
get a vafc or hondata and lean it out and fine tune your car
Old Feb 28, 2003 | 07:14 PM
Default Re: Running waaaay to rich! How can I fix this? (B20-T)
Like I said. I have the safc. I need to know if this will do the job to lean it out or if I needed the fpr?
Old Feb 28, 2003 | 07:23 PM
Smashback's Avatar
you'll be fine with what you have...and ditch the fmu
Old Feb 28, 2003 | 08:51 PM
boostaholic's Avatar
What do you have your SAFC settings to on the low rpm range? You'll need to take out a good amount of fuel at idle to get it to idle smoothly. Even with 310cc injectors, i had to take out some fuel at idle.
Old Feb 28, 2003 | 08:56 PM
shifthard's Avatar
Default Re: Running waaaay to rich! How can I fix this? (Hatchblack)
you're better off runnin rich than going lean obviously also less risk of going kaboom.... i suggest you get an adjustable fpr rather than leaning your safc...lower your fuel pressure then tune your car with the safc...oh and btw yes safc will work fine once you get your car tuned
Old Feb 28, 2003 | 09:51 PM
b16 matt's Avatar
Default Re: Running waaaay to rich! How can I fix this? (shifthard)
afc hack's suck go hondata. They call them bandaids for a reason temporary patch until you get the cash "no pun intended".
Old Feb 28, 2003 | 09:54 PM
Pengo's Avatar
Default Re: Running waaaay to rich! How can I fix this? (b16matt)
yea my engine idled pretty bad on the 310s until i got the fpr. once i lowered the pressure a lil it idled like stock
dublaaciv
Nov 1, 2005 07:08 PM
Mr.DC2TurBo
Jan 25, 2003 03:15 PM
turbod16y7vtec
Nov 2, 2002 07:43 AM
SpeedMonkeyRacing
Oct 4, 2001 07:28 AM
quick108
Aug 18, 2001 09:20 AM
