Water Pump Bad????????????
Old Feb 22, 2003 | 05:45 PM
intekragsr's Avatar
Default Water Pump Bad????????????
Im thinking my overheating problem might be my waterpump. How can I check if its bad? If I pull it out, what do I look for? Does anyone have a picture of a bad water pump?
Old Feb 22, 2003 | 06:03 PM
xsolidcellx's Avatar
Default Re: Water Pump Bad???????????? (intekragsr)
taking it out wont show u if its bad unless it has hella busted up. Why dont you check the thomostat 1st to see if it opens up. I dont rember the temp off hand but it should open up in boiling water. If it doesnt thats your prob. I'm not sure how to check the pump's flow. Even a worn pump will flow somewhat so juss looking at the radiator with the cap off might no help. In general if its not the thomostat or a blown gasket its the waterpump.
DumaDA
Jun 25, 2011 12:50 PM
Champs32
Feb 13, 2009 11:32 AM
spaceman
Apr 21, 2004 06:17 AM
intezn
Apr 4, 2003 09:20 AM
1 2 NV
May 12, 2002 09:16 AM
