water pump/coolant flow
Old Apr 20, 2004 | 08:53 PM
spaceman's Avatar
Default water pump/coolant flow
how can you tell if your water pump is working good or not?...i tried squezing the hoses while it was idleing to feel for pressure surges but i didnt feel anything and with the cap off it didnt look like water was movin,is this normal?does it need to be warmed up or more rpm's to notice?
Old Apr 20, 2004 | 09:44 PM
SleepyHF's Avatar
Default Re: water pump/coolant flow (spaceman)
The car would over heat, almost instintly if the pump was bad. Also the gasket starts to leak!!
Old Apr 20, 2004 | 10:43 PM
mmuller's Avatar
Mad Scientist
and it would most likely leak if it went bad
Old Apr 20, 2004 | 11:13 PM
civickiller's Avatar
Default Re: water pump/coolant flow (mmuller)
yes it does need to warmed up because unless its warmed up the thermostat will be closed, wait till its gets to operating temperature then try it
Old Apr 21, 2004 | 06:17 AM
spaceman's Avatar
Default Re: water pump/coolant flow (civickiller)
thanks doods
niceprelude
Feb 15, 2009 10:20 PM
Champs32
Feb 13, 2009 11:32 AM
intezn
Apr 4, 2003 09:20 AM
RenoRacing
Oct 27, 2002 08:40 PM
