1990 Integra Over Heating Issue
Today for the first time in months my car started to over heat, it has a new radiator, new coolant, new thermostat, fan is always on. The only other possibility i can think would cause the car to over heat would be a faulty water pump. Is there any other options? Is there a way to test the water pump to see if its good prior to actually having to replace it along with the timing belt? Any input would be helpful.
Re: 1990 Integra Over Heating Issue
its not your water pump if u dont see any leaks and if u dont hear anything...water pumps just dont stop working, u will hear it if it does. the reason why i say leaks is because it could be the water pump seal that has gon bad. you could have a thermostat stuck close or a very small leak in one of the radiator hoses, heater hose or the radiator itself
Old Fart
If there is no loss of coolant, I would check the thermostat, [remove it], if overheating still occurs, replace the water pump.
Rad fan should not be running all the time, so I assume it has been rewired, is it running in the right direction? 94
i checked it out earlier and the water pump is no longer working so im going to replace it and the timing belt tomorrow
cadougherty_67
03-29-2005 06:21 PM
