porsche brake conversion..................
Old Feb 22, 2003 | 12:08 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default porsche brake conversion..................
I heard about integrating porsche 4 piston caliper system w/ 94-00 integra system.
Has anyone done this compared to a regular brake upgrade?
If so do you think this is more cost effective?
I saw someone selling this on H-T but i can;t find it
Old Feb 22, 2003 | 12:35 PM
itr1244's Avatar
Default Re: porsche brake conversion.................. (MUTANT X)
I think it could be worst cost effective
Old Feb 22, 2003 | 12:38 PM
Big Phat R's Avatar
Standard R brakes are fine unless you are an elite racer. You would likely need at least 17" rims to clear those huge calipers and would have to look closely at the master cylinder fluid displacement specs to see if is compatible. The ABS system would probably have to be recalibrated also.
Porsche rims are very different from Honda/Acura rims in terms of offset - have you ever looked and seen how deeply set the rotors are?
Old Feb 22, 2003 | 12:41 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: porsche brake conversion.................. (Big Phat R)
thanks
[Modified by MUTANT X, 1:41 PM 2/22/2003]
[Modified by MUTANT X, 1:42 PM 2/22/2003]
Old Feb 22, 2003 | 01:26 PM
98cwitr's Avatar
stock brakes
Old Feb 22, 2003 | 01:51 PM
Tweakmeister's Avatar
trying to double your resale value?
Old Feb 22, 2003 | 01:53 PM
Rob :190:'s Avatar
there are a bunch of different porsche calipers. I did a little research with a 944 Turbo racer buddy, back when i thought i needed more brakes. some of the 944 turbo calipers would work, as well as some of the 911 calipers (earlier models). depending on which caliper, some would fit under 15". the calipers can be bought used for relatively inexpensive. however, you'd need custom bracketry to fit, and the damn things are pretty heavy, for a honda at least. bottom line, not worth it.
stock brakes+pads+fluid should be good enough, unless you track a lot
Old Feb 22, 2003 | 07:55 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: porsche brake conversion.................. (Rob :190:)
well i do plan to autoX and do some track events
but thanks will definitly do upgrade on what i have
Old Feb 22, 2003 | 08:19 PM
Rob :190:'s Avatar
you should be fine with the stock brakes. rotors are cheap, get good pads fluid and lines, you'll be fine. experiment with ducting and stuff if you have fading problems. if you still have problems, look into big brake kits. but skip the brembo, their kits are expensive for generic brembo calipers. stoptech and other companies make much better, honda specific kits.
all my opinion of course.
StuckeyPCS
Suspension & Brakes
Aug 6, 2010 12:25 PM
samnt650
Jul 29, 2004 06:36 AM
1QWKGS
Jul 13, 2003 05:06 AM
SSBP DC2
Jun 16, 2003 12:29 PM
CALM_AS_A_BOMB
Feb 22, 2003 12:13 PM
