Question on crx hf, to si engine swap????
Old Feb 19, 2003 | 09:14 PM
AVXHATCH's Avatar
Default Question on crx hf, to si engine swap????
Hey whats up, im new in the honda sccene , and i was wondering besides the si engine, what will i need to performe this swapp, it would be on an 88 up crx, also is there a way i can do this swapp and still pass smog if so how would i do that, i live in california so the smog is sorta strict here, is there any possible way that i can use the zc engine and still beable to get it smoged in california?? thanks dajuan
Old Feb 19, 2003 | 09:40 PM
shorti's Avatar
Default Re: Question on crx hf, to si engine swap???? (B16A6rex)
MPFI swap links:
https://honda-tech.com/zerothread?id=403065
https://honda-tech.com/zerothread?id=379732
https://honda-tech.com/zerothread?id=393895
https://honda-tech.com/zerothread?id=382444
https://honda-tech.com/zerothread?id=378202
https://honda-tech.com/zerothread?id=381596
https://honda-tech.com/zerothread?id=348343
https://honda-tech.com/zerothread?id=334228
is it honestly that hard to use the search button?
Old Feb 20, 2003 | 05:22 AM
Rob!'s Avatar
Default Re: Question on crx hf, to si engine swap???? (shorti)
your gonna need all the obvious stuff as well as si hub/knuckle assembly for axles to fit into because the hf are too small
Old Feb 20, 2003 | 08:16 AM
Mr Furball's Avatar
Default Re: Question on crx hf, to si engine swap???? (RaceFacer)
Your best friend will be a 90-92 Teg. You will also need to pull the brakes off the teg and put them on because how you gonna stop. Yes the stock is fine but soo not enough brake for that engine.
Too start I would just get the front and then pull the back sometime later and convert that crappy DRUM brake to DISC.
Old Feb 20, 2003 | 08:26 AM
Magick211's Avatar
Why would he need mpfi swap links? He has an hf its already mpfi
Old Feb 21, 2003 | 06:25 AM
Timmah!!'s Avatar
Default Re: Question on crx hf, to si engine swap???? (CivicBoyZC)
Well I have th 1.5 DX longblock, with all the Si FI parts, with the ECU. But I am still using the HF tranny. Everything is pretty much a bolt in, upgrad to the DX\SI knuckles, breaks, and axles. You will no longer have an EGR valve, so there will be no where to put that wire (I just left it hanging). One thing I am not sure about it a sensor that is on the back, right of the SI intakl manifold, on my 88HF wire harness there is no plug for it?? But the car runs good, everyonce and a withe I will get a code 1 (oxygen) and have replaced my O2 sensor several times.
If you have any more questions just IM me
CW-ITR
Apr 8, 2009 10:01 AM
duk1
Oct 13, 2007 03:45 PM
g_tech9
Classic Hondas
Aug 8, 2007 06:44 AM
-sir-
Apr 26, 2003 08:42 AM
AVXHATCH
Feb 20, 2003 05:25 AM
