washer fluid resevoir removed for turbo
Old Feb 17, 2003 | 01:11 PM
grnteg98's Avatar
Default washer fluid resevoir removed for turbo
like the topic states... for my turbo setup, we had to remove my winshield washer fluid resevoir... i was wondering if anyone else had to remove theirs and I wanted to know what you did about it, whether you just moved it or used one from a different car... any pics or ideas are welcome. thanks
Old Feb 17, 2003 | 01:13 PM
b18bturbo's Avatar
Default Re: washer fluid resevoir removed for turbo (tooslow2race)
what kit did you get, none of the turbo kits i know have anything do with winshield resovoir
[Modified by b18bturbo, 4:13 PM 2/17/2003]
Old Feb 17, 2003 | 01:27 PM
grnteg98's Avatar
Default Re: washer fluid resevoir removed for turbo (b18bturbo)
it's a custom setup, i thinks it's cause of the fmu it doesn't fit... this is in an ls as well...
-DRAG GEN 3 manifold
-Turbonetics t3/t4 turbo
-Custom Huge front mount intercooler
-Blitz Super sound blow off valve
-Vortech 12:1 FMU
-Turbonetics deltagate external wastegate
Old Feb 17, 2003 | 01:29 PM
b18bturbo's Avatar
i have to say that crzy install it shouldnt effect your winshield washer
Old Feb 17, 2003 | 01:49 PM
B18EG6's Avatar
man u can put the fmu on the firewall or strut tower... did you install all of this, or did someone else?
Old Feb 17, 2003 | 02:42 PM
LSiTurbo's Avatar
lol... where did you mount FMU that you had to hack up washer res. ?????
Old Feb 17, 2003 | 03:05 PM
TurboDANDEE's Avatar
Default Re: washer fluid resevoir removed for turbo (LSiTurbo)
I removed mine, not because of the turbo though. i couldnt use it anymore cause of my CF hood. i just took off the reservoir and left the harness hanging.
Old Feb 17, 2003 | 03:14 PM
Pengo's Avatar
Default Re: washer fluid resevoir removed for turbo (TurboDANDEE)
i dont have mine either for other reasons. nothin 30 seconds at a gas station cant solve. plus i got some windex and towels in the back just in case
Old Feb 17, 2003 | 06:36 PM
flat-blk-HB's Avatar
Default Re: washer fluid resevoir removed for turbo (Pengo)
I will proably be removing mine when i put my IC on. My 4 dr needs one and hell it will give me more room to work with.
Old Feb 17, 2003 | 07:11 PM
Flamenco-T's Avatar
Default Re: washer fluid resevoir removed for turbo (flat-blk-HB)
I removed mine for weight saving purpose....
stan
hondapwr
Apr 16, 2009 01:46 PM
WorkedDelSol
Jun 28, 2006 10:22 AM
Novtecdohc
Jun 22, 2005 09:49 AM
mpociask
Jun 6, 2004 09:25 AM
SlowPoke
Aug 31, 2001 03:17 PM
