zex kit on high mile integra?
Obviously you're running a higher risk w/ high miles but I think it would be ok. Definetly do a full tune-up and do a compression test to make sure everything's ok. Since the zex uses your existing fuel system to add more fuel I would DEFINETLY make sure that your injectors/fuel pump/fuel press. reg. are in tip top condition because if your fuel system falls short you could detonate. Make sure you use the zex plugs too. Also make sure that you don't run the bottle pressure over 1000psi. All this stuff and more is on the zex website.
yea im pushing about 160k on my car and been on the bottle since 140ish, jus do your homework, plugs are imprtant, fuel is important, and last but not least ignition timing.
MikeMAN
Jan 16, 2003 07:57 PM
