Labor cost for timing belt on b16?
Old Feb 16, 2003 | 12:01 AM
hatchii's Avatar
Default Labor cost for timing belt on b16?
is the labor cost of 120 dollars for doing the timing belt and water pump a good price? it's a side job from a friend's friend.
Old Feb 16, 2003 | 04:57 AM
mr. carpenter's Avatar
Default Re: Labor cost for timing belt on b16? (hatchii)
that sounds a little too cheap. if you're not going to do it or have a friend help you do it , i'd take it to a shop.the timing belt itself isn't much work but getting to it is a bear. plus i doubt a friend of a friend can warranty his work
[Modified by mr. carpenter, 1:58 PM 2/16/2003]
Old Feb 16, 2003 | 05:16 AM
bluecrxsi's Avatar
Default Re: Labor cost for timing belt on b16? (mr. carpenter)
that depends...is the motor in or out of the car?
Old Feb 16, 2003 | 05:48 AM
Default Re: Labor cost for timing belt on b16? (bluecrxsi)
true
Old Feb 16, 2003 | 10:50 AM
Camshaft's Avatar
120 sounds like a killer price.
I do work on the side at home....
But the thing is i'm a licenced auto tech by day
good luck
cam
Old Feb 16, 2003 | 11:38 AM
Ef Whore's Avatar
Default Re: Labor cost for timing belt on b16? (Camshaft)
this honda freak in my area does timing belts/waterpumps for 100---and he is good at his work.
Old Feb 16, 2003 | 12:09 PM
FullMetalJacket's Avatar
Default Re: Labor cost for timing belt on b16? (Ef *****)
sounds too cheap to be true...I know on my hb my dad payed $305 for new t belt,water pump,ac and alt belt and adj valves...On my crx im doing it my self..its a easy job to do..but i went to school to be a auto tech
Old Feb 16, 2003 | 12:55 PM
hatchii's Avatar
Default Re: Labor cost for timing belt on b16? (FullMetalJacket)
no this friend of my friend is currently employed at honda as a mechanic... he said he'd do it for me for about 120... the motor is still in the car.. i just have to buy the parts, but that's no problem. So should there be anything else i should do besides the timing belt and water pump?
Old Feb 16, 2003 | 01:00 PM
iwhichisme's Avatar
free!!!! do it yourself http://www.c-speedracing.com/
Old Feb 16, 2003 | 01:59 PM
Default Re: Labor cost for timing belt on b16? (iwhichisme)
if you don't mind spending the money, have him do it. you can't beat experience though. like they say , if you want something done right... .you oughta see if he'll let you help out and learn what he's doing and why. he may not be around 50,000 miles later. i'd do it if i were you but, i'd want to participate.... and not pay any money.
Old Feb 16, 2003 | 03:34 PM
cam gears and cams..that wil save you time later and a lil bit of money
vtecdc4
Jul 8, 2010 03:08 PM
WPG_5thgenprelude
Dec 9, 2005 03:58 PM
civic_hatchback
Jun 10, 2004 10:23 PM
Bobby
Nov 25, 2002 08:42 AM
daily_driver
27
Nov 23, 2001 02:53 PM
