Looking for turbo
Old Feb 15, 2003 | 11:58 AM
Mammad's Avatar
Default Looking for turbo
whats the best turbo for b16, i used audi TT turbo it was working perfectly but it started shaft playing and now i'm trying to fing another one, so which turbo do u guys recommend
Old Feb 15, 2003 | 01:03 PM
LiLOtaku's Avatar
Default Re: Looking for turbo (Mammad)
Garrett GT30 Twin Ball Bearing.
I personally will be running a GT30 with a .48 a/r and 52 trim wheel and t04b housing. These turbo's spool up 600rpm faster or more depending on you setup and 0% spool down in between shifts due to the twin ball bearing center section. The only downside is that they cost a lot. I'm getting mine for around 1250.00
Old Feb 15, 2003 | 01:09 PM
civperc's Avatar
there's no one best turbo for everyone. you should take into account where you would like spooling to begin in the powerband, when you'd like to hit full boost, how much boost you plan to run, and what power you're looking to make. figuring these variables into the "equation" will help you select the turbo and trims that're right for you.
Old Feb 15, 2003 | 03:51 PM
alpha's Avatar
Default Re: Looking for turbo (LiLOtaku)
I agree. I'm going to be using the GT30 turbocharger. It's a dual ball bearing and water cooled turbocharger.
eg8b18
Jan 30, 2015 02:58 PM
92LUDA23
Jun 29, 2010 09:00 PM
TurboMiata
May 15, 2005 04:41 AM
Pikachu
Mar 14, 2005 09:12 PM
Brian_92GSR
Apr 3, 2002 01:34 PM
