People with closed loop wastegate setups...help me with ideas
Old Feb 14, 2003 | 12:11 PM
Smashback's Avatar
Default People with closed loop wastegate setups...help me with ideas
So you've probably seen that I got my basic downpipe made, but last night I dropped the motor in the Civic and I can already see that I need one of the 90 degree wastegate elbows because it's right up against the AC lines.
I hate running an open wastegate dump, so I wanted to see pics of how your wastegate is routed when dumped back into the exhaust. You know I'll probably have to have the elbow angle the WG to the drivers side, then run the dump from there back to the passengers side somehow and route it into the downpipe under the oil pan.
Pertinent info:
96 Civic
B18B
Inlinepro manifold
5 bolt t3/4
I don't want to use the flexible tubing
Old Feb 14, 2003 | 12:16 PM
ykracing's Avatar
Default Re: People with closed loop wastegate setups...help me with ideas (Hatchblack)
this might help a little bit... it isnt exactly a street car, but you can see where my WG dumps back in...
https://honda-tech.com/zerothread?id=414543
homicydalboy
Jun 4, 2007 06:12 PM
jtracing919
Jan 21, 2006 06:24 PM
H2on0da3
Jan 4, 2006 09:43 AM
yusoslo
Apr 26, 2004 07:37 AM
rrei
Jul 18, 2002 08:06 AM
