VAFC Hack, Weird Idle?
I switched to the VAFC hack 2 days ago and my car is running pretty good now except for a weird idle problem. The cars idles good but once it has warmed up if you let idle for about 30 seconds it will suddenly bog down to about 4-500 rpm for a second and almost die, then instaltly go back to 7-800 rpm and idle fine for about another 30 seconds then do the same. While driving it runs fine, never bogs or anything. Ive tried resetting the ecu, it still does it though. Its really annoying, has anyone else seen this or have any ideas? TIA!!!
1k ive tried about 32%-40% past 40 and idle is too ruff. Have not went below 32% becuase the air/fuel read all the way lean and did not move. I Know its not accurate especially down there, but I was trying to duplicate how it read before during idle and it at least bounced some and read something. I might try lower and see what happens though.
[Modified by omahaturbocivic, 4:55 PM 2/14/2003]
you sure you dont need to clean out your IACV?...mine idled just like that I took some carb cleaner, sprayed that sucker out and idle sits nicely around 750-800rpm.
[Modified by AztecEJ, 10:35 PM 2/14/2003]
I think ill try cleaning the eacv. It was idleing fine before the hack though so I assumed it has something to do with that, unless the hack makes it more sensetive or something.
The 450s just take a little while to fully open at idle due to the size.
Richen it up to at least -30% to get a smooth idle.
I find that on my car, -25% works best.
-30%
I also have this problem and have tried practically every setting from -25% up to -50% and I still can't seem to make it idle right. The car seems either too rich or too lean, I can't seem to find a good middle ground.
I am going to try cleaning out my IAC valve though, that does sound like it could be a problem for sure.
tigueremalo
Feb 26, 2006 01:34 PM
The_Todd
Dec 16, 2003 06:28 AM
