VAFC Hack, Weird Idle?
Old Feb 14, 2003 | 08:29 AM
omahaturbocivic's Avatar
Default VAFC Hack, Weird Idle?
I switched to the VAFC hack 2 days ago and my car is running pretty good now except for a weird idle problem. The cars idles good but once it has warmed up if you let idle for about 30 seconds it will suddenly bog down to about 4-500 rpm for a second and almost die, then instaltly go back to 7-800 rpm and idle fine for about another 30 seconds then do the same. While driving it runs fine, never bogs or anything. Ive tried resetting the ecu, it still does it though. Its really annoying, has anyone else seen this or have any ideas? TIA!!!
Old Feb 14, 2003 | 10:12 AM
KC GSR's Avatar
Default Re: VAFC Hack, Weird Idle? (omahaturbocivic)
mine does that too every now and then
Old Feb 14, 2003 | 12:49 PM
RAWB's Avatar
How much FUEL are you trimming at 1K RPM?
Old Feb 14, 2003 | 01:28 PM
accordexchange's Avatar
yea, how much fuel are you trimming..? you might be running rich in the low end... you should get it tuned-
Old Feb 14, 2003 | 01:33 PM
Default Re: VAFC Hack, Weird Idle? (accordexchange)
1k ive tried about 32%-40% past 40 and idle is too ruff. Have not went below 32% becuase the air/fuel read all the way lean and did not move. I Know its not accurate especially down there, but I was trying to duplicate how it read before during idle and it at least bounced some and read something. I might try lower and see what happens though.
[Modified by omahaturbocivic, 4:55 PM 2/14/2003]
Old Feb 14, 2003 | 01:35 PM
Tomek's Avatar
you sure you dont need to clean out your IACV?...mine idled just like that I took some carb cleaner, sprayed that sucker out and idle sits nicely around 750-800rpm.
[Modified by AztecEJ, 10:35 PM 2/14/2003]
Old Feb 14, 2003 | 01:45 PM
Default Re: VAFC Hack, Weird Idle? (AztecEJ)
I think ill try cleaning the eacv. It was idleing fine before the hack though so I assumed it has something to do with that, unless the hack makes it more sensetive or something.
Old Feb 14, 2003 | 02:14 PM
rioninja's Avatar
The 450s just take a little while to fully open at idle due to the size.
Richen it up to at least -30% to get a smooth idle.
I find that on my car, -25% works best.
Old Feb 14, 2003 | 02:27 PM
Default Re: VAFC Hack, Weird Idle? (Rioninja)
Ill try goin that rich then, Thanks!!!
[Modified by omahaturbocivic, 5:49 PM 2/14/2003]
Old Feb 14, 2003 | 02:28 PM
KC GSR's Avatar
yep, -25% is what mine is set to also
Old Feb 14, 2003 | 03:05 PM
CivicSoul's Avatar
Default Re: VAFC Hack, Weird Idle? (KC GSR)
Mine is set to 59%! And it idles fine! The problem comes at slight throttle
Old Feb 14, 2003 | 03:19 PM
TurbothisLS's Avatar
i second that
-30%
Old Feb 14, 2003 | 06:50 PM
CzanSOHC's Avatar
Default Re: VAFC Hack, Weird Idle? (TurbothisLS)
I have my 440cc's -48 at idle and they idle perfect. but my car does the same thing once in a while too. I'll try -30 but that seems way to rich at idle.
Old Feb 15, 2003 | 07:51 AM
Default Re: VAFC Hack, Weird Idle? (CzanSOHC)
I tried -30 and it idled fine for several minutes withouht a single stutter, Thanks guys !
Old Mar 5, 2003 | 10:04 PM
95gsrturbo's Avatar
can the hack idle 550cc's or just the 440/450dsm
Old Mar 6, 2003 | 12:06 AM
Joseph Davis's Avatar
Default Re: VAFC Hack, Weird Idle? (95gsrturbo)
I know of the hack idling 720cc's, but there were some rich/flat spots on tip in.
550's you should be safe with.
Old Mar 6, 2003 | 03:26 AM
swlabhot's Avatar
Default Re: VAFC Hack, Weird Idle? (CivicSoul)
You're not talking about the AFC right? It only goes up to 50%. How did you get 59%!?
Old Mar 6, 2003 | 04:47 AM
Evil EG's Avatar
Default Re: VAFC Hack, Weird Idle? (swlabhot)
The SMC+ can cut out up to -59%
Old Mar 6, 2003 | 10:02 PM
M-EJ1's Avatar
Default Re: VAFC Hack, Weird Idle? (BVM)
I also have this problem and have tried practically every setting from -25% up to -50% and I still can't seem to make it idle right. The car seems either too rich or too lean, I can't seem to find a good middle ground.
I am going to try cleaning out my IAC valve though, that does sound like it could be a problem for sure.
welfarepc
Sep 13, 2007 05:15 PM
tigueremalo
Feb 26, 2006 01:34 PM
ExVtec
May 16, 2004 07:48 PM
The_Todd
Dec 16, 2003 06:28 AM
BoostedD15B7
Nov 12, 2003 05:53 PM
