Smooth idle fuel setting on afc?
Old Nov 12, 2003 | 08:31 AM
BoostedD15B7's Avatar
Default Smooth idle fuel setting on afc?
What should my fuel be set at for idle on the safc? Ive seen some people that had -19 with 450cc and some that had -40 with 450cc. Does anyone know what is a good base idle fuel setting?
Old Nov 12, 2003 | 08:39 AM
Mr. Softee's Avatar
Default Re: Smooth idle fuel setting on afc? (BoostedD15B7)
-30 worked on tegasaurus's car way back when.
Old Nov 12, 2003 | 09:05 AM
m R g S r's Avatar
Default Re: Smooth idle fuel setting on afc? (94goldjungsr)
My idle sucks, after decellerating my car drops to about 200 rpms and then raises back up. It is better now that it is cold for some reason, but when it's hot it will just stall.
Old Nov 12, 2003 | 09:13 AM
99lspwr's Avatar
Default Re: Smooth idle fuel setting on afc? (m R g S r)
set both high and low fuel maps to -29/-29 @ 1000 rpms and change your ne points to 1500/2500/3500/4500/5500/6500/7500/8500....this will make for a good idle and smoother overall driveability...
Old Nov 12, 2003 | 09:22 AM
ScottEK's Avatar
Default Re: Smooth idle fuel setting on afc? (99lspwr)
Anything under -29 (-30,-31,-32 etc) makes my car shake, I have it at -28 right now and notice a little puff of smoke when I first go to move the car, I'd rather be rich at idle then dealing with hearing stuff rattle.
Old Nov 12, 2003 | 01:48 PM
99lspwr
I have the afc2 and have 12 ne points. ANy suggestions
Old Nov 12, 2003 | 05:25 PM
ross1459's Avatar
i have mine set at -31 at 1000 but i have the automatic DSM 390cc injectors. my idle hangs fairly smoove at around 600. it dies at traffic lights sometimes though. i had a great idle at -28, unfortunately, since i run with an open downpipe, the ultra-rich smoke and stink was a little too much for me.
Old Nov 12, 2003 | 05:31 PM
NuclearB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">set both high and low fuel maps to -29/-29 @ 1000 rpms and change your ne points to 1500/2500/3500/4500/5500/6500/7500/8500....this will make for a good idle and smoother overall driveability...</TD></TR></TABLE>
can you post up what you have your settings at each of those intervals?
Old Nov 12, 2003 | 05:53 PM
scttydb411's Avatar
at 1000 rpm i've got mine set at -47. i also adjusted my throttle cable and idle just after doing so. idles like stock and no more stalling when comming to a stop light/sign.
themorphious
Engine Management and Tuning
Mar 24, 2012 08:46 AM
welfarepc
Sep 13, 2007 05:15 PM
turboB16RFD
Oct 9, 2005 09:15 PM
Hyaboosta
Jul 13, 2005 02:14 PM
ExVtec
May 16, 2004 07:48 PM
