Quick ? for all you OBD2 to OBD1 guys
Old Feb 10, 2003 | 11:09 AM
Erik B's Avatar
Default Quick ? for all you OBD2 to OBD1 guys
Did your idol change at all? I use to idol at 1g...nice and even..now I did the OBD1 conversion and my idol is at 1200 and goes to 1500 and back down Not at warm up either...it does it once the car has warmed up too. Just to give you a lil history on my car it's a 200 ITR and I did the GSR OBD1 conversion. The car is stock except for AEM fuel rail and B&M FPR. I have a VAFC but it's zero'ed out. It runs fine. I haven't really got on it cuz I'm braking a ACT clutch in. I took her to about 7g's today and shifted really soft into 3rd. I'm use a bumble bee harness for the ECU too. Thanks for any help.
Old Feb 10, 2003 | 07:23 PM
black-hatch's Avatar
Default Re: Quick ? for all you OBD2 to OBD1 guys (Erik B)
hmm set ur idle speed to stock and try unpluging the negative battery terminal for like 5 min also u said u have a fpr check and make sure the pressure is correct
Old Feb 11, 2003 | 04:01 PM
Erik B's Avatar
Default Re: Quick ? for all you OBD2 to OBD1 guys (black-hatch)
How do I set the idel speed to stock Also what FP should I be at?
Old Feb 12, 2003 | 03:06 PM
Erik B's Avatar
Anyone?
Old Feb 12, 2003 | 04:00 PM
sgT's Avatar
sgT
tryunplugging your evap solenoid
mitchell_2kSiR
May 23, 2008 01:49 PM
vtec-adykt
Apr 14, 2007 10:42 PM
B18 CYA
Jun 1, 2004 11:22 AM
civicnar
Apr 5, 2004 08:09 PM
otakueric
Mar 2, 2004 09:57 AM
