obd2 and obd1
Old May 23, 2008 | 12:51 PM
mitchell_2kSiR's Avatar
Default obd2 and obd1
with my swap for my turbo install, do i totally remove my obd2 right out of my car and use the plug in adapter and only have my obd1 in its place or do i hace to keep my obd2 in AND have my obd1 beside it? i think i already knwo the answer to just take it right out, but correct me if i'm wrong, i dont think anything will run off of it after i convert it right?
Old May 23, 2008 | 01:26 PM
J. Mills's Avatar
I'll be helpful, but you should search a little more.
You take your stock (obd2) ecu out of the car completely. If you don't have a conversion harness you need to buy one. The conversion harness plugs into your stock harness. The other side plugs into your new (obd1) ecu. Then your good to go and ready for a tune
Old May 23, 2008 | 01:49 PM
Default Re: (J. Mills)
done, and DONE thanks for the clarity
novaslean
Apr 14, 2010 09:23 AM
uses0ap
Feb 17, 2009 01:16 PM
NOman0608
Jul 26, 2007 10:28 AM
BLUE EH3
May 13, 2005 08:19 PM
