beaks kit question(did search)
Old Feb 7, 2003 | 10:19 AM
SoloSol's Avatar
Default beaks kit question(did search)
For a 93 delsol si
Suspension: H&R sports, Agx's, Progress rear bar, small version. No xtra brace.
Question is- Do I need the kit for this install?
https://honda-tech.com/zerothread?id=325172 Found this, Just want to verify
http://www.beaksproducts.com/eg-quickswap.html
TIA
Old Feb 7, 2003 | 10:28 AM
Katman's Avatar
Default Re: beaks kit question(did search) (SoloSol)
For a 93 delsol si
TIA
well, if you don't have rear sway bar mounting hardware already, imho, you should get it. It's a way good mounting kit, and reinforces your rear lower subframe, as delsol subframes are known to 'rip' if not reinforced.
[Modified by Katman, 11:29 AM 2/7/2003]
Old Feb 7, 2003 | 10:40 AM
SoloSol's Avatar
Default Re: beaks kit question(did search) (Katman)
I do have the standard mounting hardware that it came new with . I bought this used from a friend. I will be using this car for 10-12 auto-x and at least 4 HPDE's this year.
Old Feb 7, 2003 | 12:11 PM
Katman's Avatar
hmm, we'll I'd say try out the stock mounting hardware first but keep and eye out on your subframe.
You planning to go ITR rear swaybar at all?
Old Feb 7, 2003 | 12:21 PM
SoloSol's Avatar
This progress bar is a 22mm, just called the dude who sold it to me. Isnt that the same size as the ITR? Is there an advantage to getting the itr over what i got?
I will def. keep an eye on it.
Old Feb 9, 2003 | 10:32 AM
Katman's Avatar
US ITR rear swayzee is 22mm also, but progress should have their own mounting hw for their own bar; did yours come with a mounting kit from Progress?
As far as advantage, they should be close to being the same.
Old Feb 9, 2003 | 12:29 PM
piscorpio's Avatar
While on this topic, I have always been skeptical of the beaks kit. Does it really work? I mean, I can't really see how thick "washers" do all that much reinforcing unless they were welded to the frame or something. They certainly don't seem much wider than the bracket, so are they really distributing the stress any better?
I have the Susp. Tech rear sway bar, so maybe the hardware it comes with is a little different than other kits. It does have mounting plates that are thinner than the Beaks, but they are wider all around.
95vxtealhatch
10
Jul 15, 2007 08:09 PM
R.Kelley
Suspension & Brakes
Jan 23, 2006 07:26 AM
Eee Pee
21
May 5, 2004 02:22 PM
civicmatt
21
Aug 21, 2002 04:54 AM
backlash
Mar 14, 2002 10:54 AM
