7 flywhell bolts ok?
Old Feb 6, 2003 | 03:38 PM
bambooluv's Avatar
Default 7 flywhell bolts ok?
Im posting this for a friend jasonp he recently had troubles with his act clutch which exploded and messed up his eagle crank his question now that everything is back together theres one bolt thread that is pretty much gone on the crank is it ok to run 7 flywheel bolts as compared to 8 thanks-pdang
Old Feb 6, 2003 | 03:41 PM
turbohonda's Avatar
Default Re: 7 flywhell bolts ok? (bambooluv)
I am sure it will hold but it will throw the balance off.
Old Feb 6, 2003 | 03:52 PM
earl's Avatar
Default Re: 7 flywhell bolts ok? (turbohonda)
I would try to repair the threads in any way possible. If 7 were enough, Honda would have made it that way.
Old Feb 6, 2003 | 04:35 PM
turbohonda's Avatar
Default Re: 7 flywhell bolts ok? (earl)
Heli-coil it.
Old Feb 6, 2003 | 04:45 PM
b19coupe's Avatar
I would fix it.
Old Feb 6, 2003 | 04:54 PM
paulzy's Avatar
Default Re: 7 flywhell bolts ok? (b19coupe)
it should be pretty easy to tap new threads
Old Feb 6, 2003 | 08:33 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: 7 flywhell bolts ok? (1320development)
we had to retap one on a 3sgte toyota motor. it worked fine and held up great. retap it just to be safe.
Old Feb 6, 2003 | 11:40 PM
Adam F's Avatar
Default Re: 7 flywhell bolts ok? (MotorMatrix.com)
I wouldn't run it with 7 I would fix it.
Old Feb 8, 2003 | 04:42 PM
TREVER's Avatar
Default Re: 7 flywhell bolts ok? (Proelite103)
thread insert it. don't just tap or spring it (heli coil).
As stated, if seven was enough honda would have done it
Old Feb 9, 2003 | 09:15 AM
Jared's Avatar
Default Re: 7 flywhell bolts ok? (TREVER)
Dont use helicoils, they suck, use a timesert insert, they are great. do you think it could be fixed by just using a bottoming tap?
Old Feb 9, 2003 | 05:53 PM
jasonp's Avatar
Default Re: 7 flywhell bolts ok? (jtrbocrx)
ok. I will fix it but where do I get a timesert insert from and how do I fix it.
Old Feb 9, 2003 | 06:37 PM
integra_gsr98's Avatar
Default Re: 7 flywhell bolts ok? (jasonp)
http://www.timesert.com/
Old Feb 10, 2003 | 10:30 AM
giooooo's Avatar
i thought i was the only one..
https://honda-tech.com/zerothread?id=408586
anyone know the size of the flywheel bolt and what tap i should use? i look on line there is only m12x1.25 i think the flywheel bolt is m12x1.0 not sure i have to check..
spens 91 Ef
Jan 30, 2016 07:07 AM
bootlegtrader
Aug 19, 2005 05:09 PM
LsTurbo91
Jul 21, 2005 05:41 PM
TURBOFTW
Jul 10, 2004 03:21 PM
MisterB
Sep 10, 2003 11:24 PM
