Things to look for when purchasing a JDM motor
Old Feb 2, 2003 | 12:57 PM
NightHawkC5's Avatar
Default Things to look for when purchasing a JDM motor
What are some things to look for, service or check when purchasing a used JDM motor. What are some things that usually go bad or are in bad condition.................Thanks
Old Feb 2, 2003 | 01:17 PM
JDM CTR '00's Avatar
Default Re: Things to look for when purchasing a JDM motor (NightHawkC5)
check the sensors, those are the pieces that are broken most of the time
Old Feb 2, 2003 | 04:21 PM
SlapSmak's Avatar
sensors are replaceable. check compression, do a leakdown test. look at all seals: rear main, head gasket. pull the plugs if you can and take a look at them to check for detonation or oil burning
Old Feb 2, 2003 | 04:55 PM
Default Re: Things to look for when purchasing a JDM motor (SlapSmak)
Well he did ask what to look for. So he should check for those too.
Old Feb 2, 2003 | 06:11 PM
BERT-O's Avatar
If you happen to have a chance to pick out an engine. Pick the one that have a Honda OEM oil filter. This will assure you it was services at the Honda dealership.
Chances are, it was very well maintain.
Just from experience.
Old Feb 3, 2003 | 11:25 AM
Default Re: Things to look for when purchasing a JDM motor (SANBST)
I heard that thte injectors are usually dirty
Old Feb 3, 2003 | 11:33 AM
Eva01's Avatar
Little OT but if that's the case check this thread that I was just looking at: how to clean injectors
SiYouLater
Oct 23, 2008 10:27 PM
dornon13
Oct 28, 2004 05:36 AM
daver
Jul 31, 2003 08:10 PM
Witty
Oct 25, 2002 10:25 AM
