turbo f22 1/4 mile times
Old Feb 1, 2003 | 09:12 PM
Furry
Guest
Posts: n/a
Default turbo f22 1/4 mile times
i did a search and couldnt find anything..... but i've got a 92 prelude s with teh f22a1 in it and im thinking of slaping the 1g dsm junkyard turbo w/afc hack on it while i am rebuilding my h22. i wana know what kind of times you people are running. im asking here b/c more accord people turbo the f22 than prelude people. im planning on running some sort of small front mount, 10-12 psi using the afc hack and the 440cc injectors.
Old Feb 1, 2003 | 11:19 PM
WheAs MaI MojO's Avatar
Default Re: turbo f22 1/4 mile times (Furry)
this may not be totally related but a friend who owns 98 ex sedan 5 speed with fmax kit running 10lbs of boost, dyno tuned runs 13.8 at the track with 18" konigs and full interior. As far as turbo goes, he swapped out the deltagate wastegate and hks bov that comes standard in fmax with a greddy type s bov and a tial wastegate. This is because deltagate wastegates are notorious for having boost creep. Boost creep is when the wastegate is set to 8 lbs and once in a while, it will go up to 12-13 lbs. That is obviously bad.....anyways, im plannin on running the same set up as him and turbo f22s with gutted interior, gutted cat, etc should run mid 13s.....
Old Feb 1, 2003 | 11:27 PM
iam7head's Avatar
Default Re: turbo f22 1/4 mile times (WheAs MaI MojO)
mojo gonna swap out the f23 for a f22?
Old Feb 2, 2003 | 09:54 AM
Default Re: turbo f22 1/4 mile times (iam7head)
i did not say that. I am going to boost my f23
Old Feb 2, 2003 | 11:23 AM
twkdCD595's Avatar
you could put together a cheap turbo setup very easily.
by the way if your looking for a cheap dsm turbo, check the sig... price is negotiatable. condition is as stated.
check out the forced induction forum and search about budget turbo setups... been very covered topic.
[Modified by twkdCD595, 2:24 PM 2/2/2003]
Old Feb 2, 2003 | 01:32 PM
Furry
Guest
Posts: n/a
Default Re: turbo f22 1/4 mile times (twkdCD595)
ill keep you in mind..... there is a local junkyard that has a thing every sat.... 60 bux for all you can cary across the scales..... you pull what ever you want and tote it across the scales.... 60 bux everytime you take something. so im plannin on gettin everything i need from a 1g eclipse this weekend
Old Feb 2, 2003 | 02:13 PM
jweller's Avatar
wonders if he can carry a h22 bottom end in one trip, head in another. swap for $120
Old Feb 2, 2003 | 02:15 PM
Furry
Guest
Posts: n/a
Default Re: turbo f22 1/4 mile times (jweller)
if i do see any honda engine worth yanking you better believe im gona find it in me to tote the whole thing
Old Feb 3, 2003 | 12:40 PM
Maybomb119's Avatar
I apologize for my ignorance, but what would be the benefits of going from f23 to f22? would it be like the equivelant to like swapping an h23 to an h22?
Old Feb 4, 2003 | 06:05 AM
dennis's Avatar
I witnessed someone run a 13.7 - full interior with 17's. This was on a pseudo homemade setup too. Small turbo, low boost.
Old Mar 11, 2003 | 06:37 PM
papa_smurf's Avatar
hey furry, what ever happened with those s2000 pistons you were trying to swap inot an h22? that ever work out for ya?
turboek97
Sep 12, 2008 12:58 AM
Beau Gotti
Feb 3, 2005 11:52 AM
SBCCIVIC
Jun 21, 2004 06:50 PM
boosted_dc2
Dec 17, 2003 09:32 PM
Cyber ITR
Dec 9, 2001 01:51 AM
