P30 ECU,What vtec crossover are you using?
Old Jan 30, 2003 | 04:23 PM
Wong Wonder's Avatar
Default P30 ECU,What vtec crossover are you using?
I own a ls/vtec with a b16 head and b18b block running on a P30 ecu. I am trying to configure my vtec crossover on my vafc.
What should I set my Low to High cam rpm's at?
What should I set my High to Low cam rpm's at?
Thanks
Old Jan 31, 2003 | 07:55 PM
Default Re: P30 ECU,What vtec crossover are you using? (Wong Wonder)
ttt
Old Feb 1, 2003 | 09:34 AM
bump
Old Feb 1, 2003 | 01:11 PM
ce's Avatar
ce
You need to go to a dyno and find out man..That's the only way..VTEC is at 5000 on my chip now thanks to some dyno tuning..
Set it to 3000 rpm and do a run..Then to 7000 and do another run..Set VTEC to the point where the torque curves cross..
Old Feb 1, 2003 | 03:58 PM
Default Re: P30 ECU,What vtec crossover are you using? (ce)
there are no dynos where i live
DC2teggY
Apr 6, 2009 02:37 PM
chulopilong
Jul 25, 2004 07:10 AM
Nospace
Dec 29, 2003 01:14 PM
1 2 NV
Apr 12, 2003 10:01 PM
turbodsmpower
Mar 29, 2003 04:25 PM
