bad TPS?
Old Jan 29, 2003 | 01:42 PM
JDMCivicHatch93's Avatar
Default bad TPS?
how can i tell if i have a bad TPS. what kinds of symtoms might one have if it did go bad?
Old Jan 29, 2003 | 01:45 PM
sgT's Avatar
sgT
Default Re: bad TPS? (JDMCivicHatch93)
check engine light is a start
Old Jan 29, 2003 | 02:14 PM
Default Re: bad TPS? (sgT)
right........... and besides that?
Old Jun 16, 2003 | 11:00 PM
DOMKID's Avatar
will a bad TPS cause a slight hesistation/bogging at WOT?
Old Jun 16, 2003 | 11:18 PM
mmuller's Avatar
Mad Scientist
Default Re: bad TPS? (Dominican_Kid)
why dont you just check it 4.5 at wot and .45 at idle
Old Jun 17, 2003 | 04:18 AM
Bontke's Avatar
Default Re: bad TPS? (mmuller)
If you can get an analogue voltmeter (has an analogue readout instead of a digital one) you can test the TPS. Hook up the gauge to the correct wires and take the tps from idle through wide open throttle. If the analogue needle jumps itrratically at any moment you probably have a bad TPS.
If you have a bad spot in the TPS the car wil stumble and hesitate at a certain throttle position almost every time.
Throwback23
May 4, 2010 09:33 PM
Tronix102
Dec 9, 2004 07:50 PM
SpoolnG2
Jan 1, 2003 08:32 AM
soHybridized
Mar 13, 2002 10:22 AM
Wes d
Mar 1, 2002 07:36 PM
