swap trouble
things to fix idle:
adjust the idle screw on the trotle body
check u dont have vacum leaks
check the tension the trotle cable
make sure ur car its on the right timing.. advance timing advances rpms...
my buddy its s tuner on engines... he ahs a LS on his rex.. and for some weird reson it always idles between 1-1.5k
let the car warm up also.. to see if the IACV shuts off and lowers ur idle
are you sure you got all the vacum lines in the right places, i know the ls has mad vacum hoses, so just play around w them a little . i had the same problem
Now its surging from 1000 to about 1600 at idle Checked the iacv replaced it with a good one same problem if i unplug the iacv it idles fine at about 850
Car Tweaker
Sep 13, 2009 08:28 PM
headhunter
Aug 18, 2003 08:14 PM
