idle problem
idle problem
the car runs at 1200 and i tryed everything adjusting the timing , idle control valve and cleaning out the iac sensor does any body now anything about this
make sure your throttle cable isn't too tight, check the little idle adjustment screw, and try taking off the fitv, unbolting the plate which is 2 philips, and then use a flat head and screw the plastic thing all the way in.
Re: (Hanmin)
hay i tryed to adjust that screw u wer talkn about n it didnt do anything so i replaced both iac n the fitv n its still surgn do u think it can be the spark or electrical problem
Re: (Hanmin)
I checked the throtle cable the pcv valve n the vacume lines . i read some were that the voltage reulator is in the altornator or it could be the distributor .
