Law of unintended consequences...
Old Jan 24, 2003 | 01:18 PM
ion_four's Avatar
Default Law of unintended consequences...
Boost is good...but, what ill effects can it produce on your car? Last night I checked my PCV valve and realized that is was shot and that I could blow through it both ways. Using my boost gauge, a while back, I found out I could only produce about 1.5psi of pressure...this means that when boosting I'm possibly pushing upwards of 7psi into my crankcase!
Hooking up catch-can prior to turbo, tonight.
This got me thinking about other things that might be bad, particularly...how will extended periods of boost (1/4 miles, road course, etc.) affect your brake booster and thus the effectiveness of your brakes?!
Should the vac. source be relocated to the intake pipe before the turbo? Are we slowly killing our boosters? I honestly have barely any idea how these work, but it doesn't seem that this would be good.
What about EGR and charcoal canister systems?
Old Jan 24, 2003 | 01:23 PM
Smashback's Avatar
Default Re: Law of unintended consequences... (ion_four)
Well, that makes sense but I think if you hook the PCV up to the turbo intake, the turbo will be pulling air thru the filter all day instead of thru the PCV. I'm not sure if there's really any vacuum in your intake tube?
Also, if there were any REALLY ill affects, I'd think somebody would have noticed by now. Some guys have had turbos on for years and years and I've never heard of anybody blowing up a brake booster or anything.
Old Jan 24, 2003 | 01:32 PM
BudaKai's Avatar
You need to check the threads already going we had this discussion already. You're bringing up stuff I always thought about. I moved all my vacuum lines so they would actually get vacuum. Better to be safe than sorry.
Here: https://honda-tech.com/zerothread?id=394876
There's vacuum if the air is moving at any kind of rate through a restricted orifice like a intake tube attached to the turbo. It's also been my experience that some of the guys rolling around with turbo'd cars from old aren't too keen on the actually upkeep so their car are unrelieable then after a while (2-4yrs.) they get out and sell the car. A brake booster won't just die in 2 years. They're made to last at 10 years. I would think it would just shorten the life.
[Modified by tzsir, 4:38 PM 1/24/2003]
Old Jan 24, 2003 | 01:34 PM
sharkcohen's Avatar
Default Re: Law of unintended consequences... (tzsir)
Glad I don't have this issue with my catch can on my JRSC setup.
Old Jan 24, 2003 | 01:37 PM
Smashback's Avatar
Default Re: Law of unintended consequences... (sharkcohen)
LOL I guess you need to have some kind of reason to justify running one of those things
j/k now!
Old Jan 24, 2003 | 01:41 PM
b18cya's Avatar
Default Re: Law of unintended consequences... (Hatchblack)
somehow i doubt that you'll be using your brakes while boosting...so i dont see how the brake booster woudl be effected in any way
Old Jan 24, 2003 | 02:23 PM
ion_four's Avatar
Default Re: Law of unintended consequences... (b18cya)
yeah, not while...but immediately afterwards haha.
Old Jan 24, 2003 | 06:22 PM
lazerus's Avatar
I totally here you there. lol
thenext
Jul 26, 2011 12:56 PM
turbohatch96y7
Jun 18, 2009 06:51 AM
3k9civic
25
Aug 24, 2005 06:12 AM
apexrift
Mar 1, 2005 12:59 PM
OKSolSi
May 20, 2002 04:31 PM
