Frankenstein Engine - VTEC solenoid
Old Jan 22, 2003 | 01:01 PM
WalkEX99's Avatar
Default Frankenstein Engine - VTEC solenoid
I have a frankenstien engine (CRV block with a Type-R head) installed in a 2001 Integra. The engine is gettting fuel cut-off at about 5000 rpm. I have been told that the VTEC solenoid is not plugged in because the wiring harness is missing this wire. I am looking for a way to 'hot wire' the VTEC solenoid.
Old Jan 23, 2003 | 04:49 AM
XKWISIT1's Avatar
Default Re: Frankenstein Engine - VTEC solenoid (WalkEX99)
the easiest way would be to find a RPM activated switch, Moroso make one ,to activate the solinoid
Old Jan 23, 2003 | 11:49 AM
bruthaboost's Avatar
Any twelve volts source will open the vtec solenoid, however you still need to find out why your fuel is getting cut. "Hot wiring" vtec will do nothing but open the solenoid. Are you getting codes?
swizz977
10
May 25, 2011 08:15 PM
tarmax
Oct 20, 2010 11:40 AM
Mr. Thunderlips
20
Jun 8, 2003 01:21 AM
WalkEX99
Jan 23, 2003 04:48 AM
WalkEX99
Jan 22, 2003 02:37 PM
