2k1 civic turbo fuel
Old Jan 22, 2003 | 09:22 AM
2k1civicturbo's Avatar
Default 2k1 civic turbo fuel
hey i just got a turbo for my 2k1 civic.....i am running 5 psi with stock internals....i know i need to upgrade my fuel and but i was wondering if anyone can help me on what i need. i know i need a vortech fmu, bigger injectors, bigger fuel pump...and...i dontk now wat else. How long do you think i can last without any fuel mods?
Old Jan 22, 2003 | 09:24 AM
yellowsub's Avatar
Default Re: 2k1 civic turbo fuel (2k1civicturbo)
Just stay outta boost.
Old Jan 22, 2003 | 09:33 AM
reXem's Avatar
Default Re: 2k1 civic turbo fuel (yellowsub)
Wow, thanks for the input *******.....
As for on topic, for 5 psi on my ZC I didnt really do much extra to the fuel. I ran a Adjustable FPR set like 10psi higher static and I had no troubles, no signs of detonation and it actually ran rich. to be on the safe side for you maybe get the FMU and that should be ok, if you have the money the AFC Hack works well. A walbro FI intank pump works well if you want a new pump that can handle higher PSI. Injectors really arent necessary unless you can find some 310s for cheap, anything above that and a stock ecu wont be able to run them properly. AFC hack would run up to 450s fine though.
Old Jan 22, 2003 | 10:15 AM
Default Re: 2k1 civic turbo fuel (reXem)
thanks rexem for your input......but you know that the 2k1 civic has a weird fuel system right? people have been telling me that you have to change the car into a fuel return system or something like that. i dont know i am a nub when it comes down to turbos. I will get the fmu this week and get that put in asap. the afc??....i dont know....because i know that **** cost like 300 dollars...after the custom turbo kit my wallet is hurting you knwo what i mean..hahahahahahhaaa...thanks again...and no thanks to the other post....
Old Jan 22, 2003 | 10:17 AM
reXem's Avatar
I didnt know the new civics used a return less system, well then I dunno what to do...does it use a MAP sensor? if so the SMC would work for you do some searches on SMC
Old Jan 22, 2003 | 10:19 AM
highbrid's Avatar
i think you are correct in saying that the newer civics dont have a fuel return line like the older civics have. I dont know what the fpr would look like or how exactly it works, or if it even has one, but id say get one if you can. 5 psi is really low boost though and you should not need much if anything, just dont get a boost controller.
Old Jan 22, 2003 | 10:20 AM
Tony Starks's Avatar
Not sure about your cars fuel system, but I have an MSD inline and a 12:1 vortec FMU if you would like to buy them. i strongly recommend doing some more research on your car before you boost it. Get a Helms. Best $60 you'll ever spend. IM me if you want the fuel pump and the FMU.
Old Jan 22, 2003 | 11:15 AM
Default Re: 2k1 civic turbo fuel (Tony Starks)
hey tony i e mailed you but just incase you dont get it i am interested in buyings your stuff. would it fit my car though? if it does i am interested. e mail me at roylee0484@yahoo.com thanks.
MotorMatrix.com's Avatar
I am a bad person
the 2k1 civic has no return line and the pressure regulator is in the tank according to the manual. its the same as the rsx and new civc si.
Old Jan 22, 2003 | 11:23 AM
reXem's Avatar
Default Re: 2k1 civic turbo fuel (MotorMatrix.com)
so does anyone make an adjustable regulator? is it even possible?
Old Jan 22, 2003 | 11:25 AM
Turbo D17's Avatar
Nope. You need to either convert to a return system or use a fuel computer to control bigger injectors or an additional injector.
Old Jan 22, 2003 | 11:48 AM
reXem's Avatar
Default Re: 2k1 civic turbo fuel (Turbo D17)
how hard is it to convert? my buddy has a focus and would probably be interested
Old Jan 22, 2003 | 06:33 PM
so tony do you have that fmu??...i am looking to get it this week
Old Jan 23, 2003 | 04:09 AM
pm'ed you
Old Jan 23, 2003 | 04:48 AM
reXem's Avatar
That FMU will not work for you, you need a normal returning fuel system. Returnless systems cant use them
Old Jan 23, 2003 | 07:17 AM
are you sure? i know people that use the same fmu.
Old Jan 23, 2003 | 07:57 AM
Turbo D17's Avatar
Don't see how that's possible on a returnless fuel system...
Old Jan 23, 2003 | 08:03 AM
Smashback's Avatar
Haha I don't think Tony Stark is his real name...unless he's Iron Man damn I haven't seen him for like 15 years. He was one of my favorites!
Old Jan 23, 2003 | 10:28 AM
reXem's Avatar
Default Re: 2k1 civic turbo fuel (Hatchblack)
An FMU goes in line with the fuel return....now I dunno how that would be possible on a returnless fuel system.
Old Jan 23, 2003 | 10:43 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Ask Tony1 from Jotech he can tell you how it's done. I've seen the pictures of d17's turbo set up. It's nice.
90crxsi88zc
Oct 6, 2005 03:18 PM
92civiclsb18a
Jun 30, 2004 08:41 PM
APEXI Si
Mar 8, 2003 07:49 AM
pelotudo
Sep 14, 2002 12:35 PM
zcivic91
Aug 15, 2002 05:38 AM
