d16y7 crank and d16y8 crank
Old Jan 22, 2003 | 03:09 AM
98civicEX's Avatar
Default d16y7 crank and d16y8 crank
does anyone know if there's a difference between these 2 cranks?
Old Jan 22, 2003 | 05:10 AM
TurbodCX's Avatar
Default Re: d16y7 crank and d16y8 crank (98civicEX)
i think the mains are different sized... i know the rods are the same.. i am just not real sure about the mains.. i dont think the Y7 uses a main girdle like the Y8...
if you have both of the cranks,just get both of them miked (sp?) and that will tell you the difference in them...
Brian
Old Jan 22, 2003 | 07:56 AM
boosted hybrid's Avatar
Default Re: d16y7 crank and d16y8 crank (TurbodCX)
I believe he is right. The Y8 blocks use the girdle and the Y7 cranks do not. The rod length is the same, i have personally looked at the rod sets next to each other. You may want to find out the stroke on each of those engines to double check.
Old Jan 26, 2003 | 11:32 AM
98civicEX's Avatar
Default Re: d16y7 crank and d16y8 crank (boosted hybrid)
lined them up, they look identical.
Old Jan 26, 2003 | 01:57 PM
Smashback's Avatar
If you look up part numbers for aftermarket pistons I believe they are the same. Other than the girdle and the oil pan, they seem to be indentical. I don't know about the mains, but I would think they would be the same.
Old Jan 26, 2003 | 02:01 PM
Sonny's Avatar
The parts fiche at hondaautomotiveparts.com shows that the D16Y7 and D16Y8 both use a main cap girdle.
Sonny
Old Jan 26, 2003 | 04:04 PM
Default Re: d16y7 crank and d16y8 crank (Sonny)
Strange, when my friend and i stripped down his y7 it didnt have a girdle. I might be mistaking the y7 for another d-series engine though. I am not completely up to par on d knowledge.
Old Jan 26, 2003 | 05:34 PM
Smashback's Avatar
Don't feel bad...I've had my oil pan off 4 or 5 times on my Y7 and I can't remember either
Efjams24
Jun 17, 2012 07:12 AM
1clean_ Ej
May 30, 2007 12:54 PM
7808
Feb 9, 2007 12:39 PM
hondalowlow
Jan 16, 2006 10:54 AM
Dancing is Forbidden
Sep 7, 2004 06:44 PM
