how much can i run?
Im wondering how much boost i can run on my stock internals with a 35shot of nitrous. I was thinking like 8 or 9 psi on race gas. My car is an ls with an automatic, what should i run in the 1/4 mile with that combination?
Whoa man...With stock injectors you will not be able to push the amount of fuel need to supply 9lbs of boost and a 35 shot. Please do some homework about this. Im not trying to dog you but from the post it seems like you are jumping ahead of yourslef a bit. Turbo and N/X combos are very hard to do. They are a very good way of making good power, but for someone new to the whole forced induction thing. I would say that its a bad idea. You are running an auto trans, before anything I would do a tranny swap. Just my 2 cents
[Modified by Elite Hatch, 11:47 AM 1/22/2003]
You are running an auto trans, before anything I would do a tranny swap. Just my 2 cents.
Edit: I'd say you'd beable to run around 8psi and nitrous. Around 1bar without nitrous.
[Modified by autoEXturbo, 12:16 PM 1/22/2003]
12:1 mu and 550cc injectors??? I don't think that is a good route.
autoex how are you gonna get your car to idle?
Yah idling would be the only problem. I have 440s and my low throttle is at -50 so I cant go any lower so If I did bigger injectors I wouldnt be able to idle
I can't remember where I saw it, but there's a beefed up torque converter available. I don't know if that's what likes to blow up or not, but I've seen it.
Hyjnx
Dec 22, 2002 07:40 PM
