Running lean, any advice?
Old May 10, 2003 | 04:19 PM
wzcb08's Avatar
Default Running lean, any advice?
I know my fuel management isn't the greatest but I never thought it was this bad. I just had a baseline dyno done on my Turbo LS running about 10lbs of boost. I have an intank fuel pump and a vortech 12:1 running off of stock injectors. At about 3 1/2 thousand rpms the Air to Fuel Ratio jumps all the way to 15 and stays pretty constant, we stopped the run at about 5,000 rpms. I wanted to hear of some temporary solutions just to get it running a little richer. I have some RC 310s coming. I can't afford standalone since I have an OBDII motor. Do you think 310s and safc may help in making it run rich. Should I keep the vortech 12:1 FMU when I add the bigger injectors, or is that too much pressure in the fuel lines when I get the 310s. Any advice would be great
Modified by wzcb08 at 4:43 AM 5/12/2003
Modified by wzcb08 at 4:51 AM 5/12/2003
Old May 10, 2003 | 04:46 PM
boosted_dc2's Avatar
Default Re: Running lean, any advice? (wzcb08)
run the hack, (440's vafc) vortech 12:1 sux. I cant believe it made it that lean. Mine was so rich that it stopped pulling above 5600. But i bet 310's with the 12:1 and a vafc would work too, i would rather go with the hack though. But also i dont know if 10 psi is to much for that set up??? mine was at 7 when it was richer than hell, 10 might be leaning it di you try less boost at the tuners???
Old May 10, 2003 | 04:48 PM
wzcb08's Avatar
Default Re: Running lean, any advice? (hooked_up_gsr)
Nope, the spring's lowest boost on the wastegate is 10, but i just bought a 7psi spring and will get that in there too.
Old May 10, 2003 | 05:32 PM
Westrock2000's Avatar
check my sig for advise on how to temporarily run richer.
(hint) The map sensor......
Old May 10, 2003 | 08:03 PM
wzcb08's Avatar
Default Re: Running lean, any advice? (Westrock2000)
You know I think I may try that and see what happens.
Old May 11, 2003 | 01:25 PM
Let me know if it works......
Old May 11, 2003 | 01:30 PM
omahaturbocivic's Avatar
Its just gonna force it into open loop mode. Some engines dont run to well but it should be richer .
Old May 11, 2003 | 07:24 PM
wzcb08's Avatar
Default Re: Running lean, any advice? (omahaturbocivic)
Here's a link to my A/F Graph so you can see what I was talking about. You think it's possible my FMU is not working right anymore. I have about 10,000 miles, is there any maintence that needs to be done to a vortech fmu. Let me know if the link works or not too.
[URL][http://www.villagephotos.com/pubbrow...elected=261412 /URL]
Old May 11, 2003 | 07:28 PM
b16ahybrid's Avatar
link no worky
Gravy's Avatar
i think you want this Village Photos
Old May 11, 2003 | 07:36 PM
wzcb08's Avatar
Default Re: Running lean, any advice? (GRTechnologies)
Thanks
ceemarun
Aug 26, 2005 01:33 AM
Andrew 825SM
Oct 19, 2004 09:00 AM
slow02ss camaro
Apr 8, 2003 06:50 PM
Andrew 825SM
Oct 26, 2002 08:35 PM
ludelvr
Jun 4, 2002 10:38 PM
