All I have is the FMU, what else do I need? (parts)
Old Jan 21, 2003 | 02:27 PM
VTEC-DA's Avatar
Default All I have is the FMU, what else do I need? (parts)
All I have the is the bare FMU. What other tubes, hoses etc. will I need? Also, I know the vacuum gets t'd off, one hose goes from the nipple on the FMU to the fuel rail and the other from the FMU to the tank. Where do I run the line though. Obvisouly, I dont have any directions or insturctions with my FMU. TIA.
Old Jan 21, 2003 | 02:38 PM
Cramerox's Avatar
Default Re: All I have is the FMU, what else do I need? (VTEC-DA)
basically the order goes liek this
fuel filter>inline pump>fuelrail>FPR>FMU>fuel return to tank
So after the FPR the fuel goes to the inlet of the fmu then the outlet of the FMU connects to the fuel return.
[Modified by Cramerox, 3:38 PM 1/21/2003]
Old Jan 21, 2003 | 02:39 PM
Cramerox's Avatar
Where do I run the line though...
Basically there is a fuel line that comes of the FPR the fmu goes between that line.
Old Jan 21, 2003 | 05:00 PM
VTEC-DA's Avatar
Default Re: All I have is the FMU, what else do I need? (Cramerox)
OK, I have an intake pump, so that elminates that step, but what I meant by where does the line go, I meant physically, where do I run the line throguh to get it from the FMU to the tank. Is there a special "passage" somewhere under or inside the car to get it there?
Old Jan 21, 2003 | 05:06 PM
Cramerox's Avatar
yes the line is located right after the fuel pressure regulator.
The FPR will have a vacume source...look for the fuel line the comes of the FPR.
When u find that line, the FMU bascially T's into the fuel line.
Sorta make sense?
Old Jan 21, 2003 | 05:32 PM
VTEC-DA's Avatar
Maybe I am just not phrasing my question right. If I were to trace the line from the FMU to the tank, where would I go? Under the car, through the firewall, inside the door, where? Or maybe its just a really dumb question.
Old Jan 21, 2003 | 05:34 PM
VTEC-DA's Avatar
Now I am really confused. Here is what I am getting from all of this.
1. The FMU has 2 fuel ports and a vacuum port.
2. The vacuum gets t'd off with the vacuum going into the FPR.
3. One fuel port goes to the fuel line and one goes to the fuel tank.
****, maybe I will just do the SAFC hack and screw the FMU all together. Anyone got any DSM injectors?
[Modified by VTEC-DA, 9:35 PM 1/21/2003]
Old Jan 21, 2003 | 05:43 PM
keebler65's Avatar
talk to Mike Palm he hooked me up with cleaned and balanced ones for $125 shipped. they look like new i dont know if he has more or not....it was around xmas time that i got mine.
Old Jan 21, 2003 | 07:02 PM
Cramerox's Avatar
IF you follow the fuel line comming "OFF" the FPR, that leads back to the tank. So basically the 2 fuel ports from the FMU goes between that fuel line from the FPR.
So basically locate the fuel line comming of the FPR. Then you have to cut that line. fuel comming out from the FPR goes IN to the fmu. then the out port of the FMU connects back to the original fuel line that you cut from the FPR.
Sigh i wish i had a picture....
Old Jan 22, 2003 | 12:44 PM
gtcali's Avatar
Your Pic
This is regarding the return line from the fuel rail. In from fuel rail and out to tank.
How do you just post the image? Nevermind
Stole this image from: http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
[Modified by gtcali, 1:52 PM 1/22/2003]
Old Jan 22, 2003 | 12:53 PM
gtcali's Avatar
Default Re: All I have is the FMU, what else do I need? (gtcali)
here is a better one from that site.
[Modified by gtcali, 1:54 PM 1/22/2003]
Old Jan 22, 2003 | 02:10 PM
VTEC-DA's Avatar
****, thats not complicated at all. Anyone know how long the line from the FMU to the tank has to be? And where the best place to run it is?
Old Jan 22, 2003 | 02:36 PM
Brad's Avatar
You already have a fuel return line going to the gas tank. That line, which comes from the line off the stock fpr would now be connected to the fuel out on the fmu.
Old Jan 22, 2003 | 02:38 PM
Cramerox's Avatar
there is a return fuel line in your engine bay that you tap into. You dont need a new line from the fmu going all the way to the gas tank. Make sure you use fuel line not vacume lines
Old Jan 22, 2003 | 02:44 PM
VTEC-DA's Avatar
Alright, so the line going into the bottom of the FPR, now goes into the FMU? If thats true, then I dont need to tap into anything or run any new line? If thats correct, I think I got it.
gtcali's Avatar
That fuel line out lined in red (to the tank) is currently hooked up to your fuel pressure regulator. (Assuming its stock right now)
All you do is pull the hose off the FPR and plug in to FMU. Then get some extra hose (outlined in blue) and plug that between the FMU and FPR. Then do the vacuum line.
[Modified by gtcali, 3:45 PM 1/22/2003]
Old Jan 22, 2003 | 02:46 PM
VTEC-DA's Avatar
Got it. Thanks to gtcali, cramerox and brad for dealing with my ignorance.
to all 3 of you.
Old Jan 22, 2003 | 02:49 PM
Tofurky's Avatar
to all 3 of you.
at least you had the brains to ask... i ran my fmu before the fuel rail on my old car 2 years ago, for a good month or two, till i realized..."hey this doesn't seem right"
Old Jan 22, 2003 | 02:57 PM
gtcali's Avatar
Default Re: All I have is the FMU, what else do I need? (Ruckus138)
noobs helping noobs.
Old Jan 22, 2003 | 03:02 PM
Tofurky's Avatar
that was such an insightful post. please: tell us more.
Old Jan 22, 2003 | 03:39 PM
Cramerox's Avatar
Old Jan 23, 2003 | 12:55 PM
gtcali's Avatar
You probably misunderstood me, let me clarify.
Newbie to turbo (me) helping a newbie to turbo (vtec-da).
Its hard to get an answer from the more experienced 1000 posters. Probably casue they're sick of repeating themselves. So I take it upon my self to answer the questions I know the answers to for the newbies.
Sorry for the wasted BW
ityab0y
Nov 6, 2005 09:21 AM
sporkcrx
Nov 1, 2002 04:43 PM
2K1NBGSR
Jun 11, 2002 06:56 PM
SpeedracerS4
Jan 25, 2002 09:47 PM
