lost motion assembly?
Old Jan 20, 2003 | 07:00 PM
Cottonwoodz's Avatar
Default lost motion assembly?
Do you have to pull the head, to change the lost motion assembly?
Old Jan 21, 2003 | 06:50 AM
pentaq's Avatar
Default Re: lost motion assembly? (Cottonwoodz)
definitely yes.
Old Jan 21, 2003 | 09:01 AM
2point6's Avatar
Default Re: lost motion assembly? (pentaq)
No. they can be changed without removing the head. I have done it many times.
Old Jan 21, 2003 | 09:09 AM
bgod's Avatar
Default Re: lost motion assembly? (2point6)
head does not need to be removed.
Old Jan 21, 2003 | 09:17 AM
B18EG6's Avatar
Default Re: lost motion assembly? (bgod)
cams do though, right?
[Modified by B18EG6, 1:18 PM 1/21/2003]
Old Jan 21, 2003 | 09:44 AM
2point6's Avatar
Default Re: lost motion assembly? (B18EG6)
Yes the cams need to be removed.
Old Jan 21, 2003 | 11:39 AM
pentaq's Avatar
ups. so someone made me wrong :/ sorry
What should be removed to replace lma then? It's tapping badly (over 118 kmiles)
Old Jan 21, 2003 | 01:05 PM
2point6's Avatar
Have you had a valve adjustment done lately?
Old Jan 21, 2003 | 01:31 PM
Thanks !
Old Jan 21, 2003 | 01:37 PM
pentaq's Avatar
yep. every 10kkm (7,5 kmiles). Lma are heard mostly while engine is cold (or so I was told). I saw lma after 100kmiles, they could be compressed by fingers easily. They were simply done...
Old Jan 21, 2003 | 02:12 PM
Ritteri's Avatar
2point6 is 100% correct.
Old Jan 22, 2003 | 09:51 PM
ismkv8s's Avatar
Default Re: lost motion assembly? (Ritteri)
also it depends if you have an older or newer h22.The older ones are simular to the ones in a b series and the newer ones can be taken out with the cams out.The older ons the rockers will have to be removed.
Old Jan 23, 2003 | 06:01 AM
2point6's Avatar
Default Re: lost motion assembly? (ismkv8s)
Older? Newer? Can you explain please?
Old Jan 23, 2003 | 03:32 PM
ismkv8s's Avatar
well I bought a 92 h22 and it had the same style lm assy as the b series and I have two newer open deck style and theres are just a spring.
Old Jan 23, 2003 | 10:02 PM
2point6's Avatar
the "newer" 97 and up LMA's are similiar to the ITR LMA. they are not just a spring. Can you show a pic?
Old Jan 23, 2003 | 11:55 PM
Fly1865's Avatar
I believe that the 97 H22A has the spring LMA. its the later years that have inclosed, as i would say, LMA. Have to check the Helms but its outside and i don't feel like going out to look. Tomorrow for sure.
What do the ITR LMA look like. From the Helms as i can remenber the 97 have a spring with a ball looking thing on top on it, and the later years are different.
[Modified by Fly1865, 12:56 AM 1/24/2003]
Jeremyinlinepro
36
Jan 19, 2013 10:26 PM
kingofnothing
Oct 20, 2008 05:40 PM
JDM_EK4_Coupe
May 15, 2007 06:21 PM
JDMvtecDRAGSTA
Apr 18, 2002 12:07 PM
