anyone else get a funky ticking noise from their valvetrain??
Old Jan 19, 2003 | 06:18 AM
Boostless97Lude
Guest
Posts: n/a
Default anyone else get a funky ticking noise from their valvetrain??
ok, so on my LS/VTEC Teg, i have a B16 head. for some reason i am getting this weird ticking kind of moise. it sounds kinda like valve tick, but my valves were just adjusted a couple months back so that shouldn't be a problem. anyways, when VTEC engages, the noise goes away. i figure it must have something to do with the pushrods on the VTEC rockers. if anyone has had similar problems, please, let me know
oh yeah, BTW, i posted here b/c i'm using a B16 head
Old Jan 19, 2003 | 06:27 AM
t0p_sh0tta's Avatar
Default Re: anyone else get a funky ticking noise from their valvetrain?? (Boosted97Lude)
Lets see....
First, I would recheck the valve clerances. Sometimes they are just off...
If that checks out, I'd look to the injectors. They are a common source of noise. Are they new? Maybe its time to rebild/replace them.
Old Jan 19, 2003 | 07:10 AM
B18C1 '96 Coupe's Avatar
Default Re: anyone else get a funky ticking noise from their valvetrain?? (t0p_sh0tta)
On injectors can you run fuel injector cleaner on them? I know some injectors you cant. Will that help this problem?
Old Jan 19, 2003 | 07:17 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone else get a funky ticking noise from their valvetrain?? (B18C1 '96 Coupe)
ok, that doens't make sense..... if it's the injectors making noise, then why would it go away once it goes into VTEC??
Old Jan 19, 2003 | 02:31 PM
ejprimo's Avatar
b/c vtec is louder than the injectors. my car is always making the "ticking" noise. i have concluded that it is my injectors.
Old Jan 19, 2003 | 03:23 PM
ChiBoy's Avatar
Take a look at your Lost Motion asseblies.
If you are going to re-check the valve clearences, you can check the LMA's at the same time. As you check/adjust the valves, grab the middle rocker and try to move it up and down. The LMA should keep the rocker pretty much pressed against the cam. If the rocker moves freely, the LMA may be bad.
I have a few bad ones myself and the click the same way. I'm waiting for the rebiuld to replace.
Old Jan 19, 2003 | 03:57 PM
B18EG6's Avatar
Default Re: anyone else get a funky ticking noise from their valvetrain?? (ChiBoy)
took the words right out of my mouth. Does the clicking get faste rand fastter as the rev's go up?
does it click when you are at idle? does it click when you free rev?
Old Jan 19, 2003 | 04:07 PM
rathead's Avatar
Default Re: anyone else get a funky ticking noise from their valvetrain?? (B18EG6)
had the same problem with my brothers b-16
turns out the one of the lost motion ***. was sticking
never fixed it but it comes and goes
i woundn't worry too much about it
Old Jan 19, 2003 | 04:31 PM
deepnite's Avatar
Default Re: anyone else get a funky ticking noise from their valvetrain?? (rathead-ek)
pray to motor gods its not a detonation noise
i had the same problem but the car was stolen befor i could investigate the problem
Old Jan 19, 2003 | 05:21 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone else get a funky ticking noise from their valvetrain?? (deepnite)
yeah, i know what detonation sounds like, and it sounds nothing like it. LMA is most likely what it is, that what i thought it was from the begining, i just couldn't think what the damn things were called. i was just curious if something like that was actually possible or not
Old Jan 19, 2003 | 06:05 PM
CRX_VTEC's Avatar
rod knock..
cross your fingers is isnt the rod bearings.
Old Jan 19, 2003 | 06:21 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone else get a funky ticking noise from their valvetrain?? (CRX_VTEC)
rod knock..
it's not rod knock, i know what that sound like too.... it's a clicking/ticking noise from the top end
Old Jan 19, 2003 | 06:29 PM
JD_B18CDX's Avatar
5 bucks says its worn primary rocker arms.
These arms wear faster beacuse 90% of the time your motor is running on the small lobe. No ticking when vtec is activated because vtec rocker arm is still in good shape.
Check inside diameter on the rocker arm AND outside diameter of the rocker arm shaft. Clearance should not be too big.
[Modified by JD_B18CDX, 10:31 PM 1/19/2003]
Old Jan 19, 2003 | 06:39 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone else get a funky ticking noise from their valvetrain?? (JD_B18CDX)
if that's what it is, i swear i'll send you a brand new crispy Lincoln
Old Jan 19, 2003 | 07:19 PM
viCeVerSa's Avatar
hahahah
kte324
Oct 6, 2008 08:17 PM
boomersz
23
Apr 28, 2007 10:43 AM
projectac
Jul 29, 2005 07:24 AM
zseeanz
Mar 23, 2004 02:26 PM
bananacruzier
Mar 28, 2002 10:33 AM
