Where can i find a oil inlet flange like this?*pic*
its not exactly what your looking for but, at turbonetics you can get a flange for the oil inlet that has a threaded hole. Then you can put a an fitting into that. Keep that in mind if you cant find the one your looking for.
I'd like one JUST like what's posted there... or SOMETHING that will allow me to minimize the amount of oil/oil pressure the turbo sees. Damn ITR oil pump.
you could do that by both ways that stan and I suggested. Cool thing about fittings is they have all kinds of different sizes on both ends.
you cna just buy a -3 to 1/8" NPT fitting..
I have several if you need some
Basically I dont want to buy a whole new 3AN line/fittings, I just want an easy cheap way to reduce oil pressure at the turbo.
nobody knows where i could find one with the fittin attached like the one in the pic? eh.. i guess ill just be gettin -4 to 1/8 then... would i be able to pick up a brass one at home dopot? or, id be interested in yours flamenco if 93ls doesnt want it...
you can get one from max-rev. the one that came with my kit was cnc aluminum.
I believe you can also et one from http://www.roadraceengineering.com i probably spelt that worng
they make a -3 tp 1/8" NPT or -4 to 1/8" NPT, I have both...
I'll give you one of the -4AN if you want one Dan..
stan
stan
Will my -4AN oil line/hose ends screw onto the fitting you have, and thus through your fitting reduce flow into the turbo. Im terrible at explaining myself.....ok, try again. Is your fitting basically a -4AN fitting with a smaller hole through it making it a -3AN hole.
Sorry im an idiot
I could be wrong, but doesnt it go like this:
3AN - 3/16"
4AN- 4/16" or 1/4"
Here dude I got an idea...I got a 4an hose end, and a 3an piece. Il see if it screw on for ya
Edit- nope, the 3an is a little to small for the 4an hose end.
[Modified by B18EG6, 7:13 PM 1/18/2003]
3AN - 3/16"
4AN- 4/16" or 1/4"
3AN - 3/16"
4AN- 4/16" or 1/4"
3AN - 3/16"
4AN- 4/16" or 1/4"
Correct. Ill take a pic or two if you want confirmation. But yes, the threaded sides are jussssst barely off. (doy...i guess 1/6" off)
Dan: ooh yes, they're totally different, the -3 and -4 are different in thread size..
hmm, I'd get like a -4 male to -3 female union, so you'll reduce oil press to the turbo...
pjr710
Aug 17, 2007 04:33 PM
b18cya
Feb 19, 2003 10:50 PM
