Where can i find a oil inlet flange like this?*pic*
Re: Where can i find a oil inlet flange like this?*pic* (dumbkid)
its not exactly what your looking for but, at turbonetics you can get a flange for the oil inlet that has a threaded hole. Then you can put a an fitting into that. Keep that in mind if you cant find the one your looking for.
New User
Re: Where can i find a oil inlet flange like this?*pic* (ninesecrx)
I'd like one JUST like what's posted there... or SOMETHING that will allow me to minimize the amount of oil/oil pressure the turbo sees. Damn ITR oil pump.
Re: Where can i find a oil inlet flange like this?*pic* (SiR Kid)
you could do that by both ways that stan and I suggested. Cool thing about fittings is they have all kinds of different sizes on both ends.
Re: Where can i find a oil inlet flange like this?*pic* (Flamenco-T)
you cna just buy a -3 to 1/8" NPT fitting..
I have several if you need some
Basically I dont want to buy a whole new 3AN line/fittings, I just want an easy cheap way to reduce oil pressure at the turbo.
Re: Where can i find a oil inlet flange like this?*pic* (93LSivic)
they make a -3 tp 1/8" NPT or -4 to 1/8" NPT, I have both...
I'll give you one of the -4AN if you want one Dan..
stan
stan
nobody knows where i could find one with the fittin attached like the one in the pic? eh.. i guess ill just be gettin -4 to 1/8 then... would i be able to pick up a brass one at home dopot? or, id be interested in yours flamenco if 93ls doesnt want it...
1 Post
you can get one from max-rev. the one that came with my kit was cnc aluminum.
I believe you can also et one from http://www.roadraceengineering.com i probably spelt that worng
stan
stan
Will my -4AN oil line/hose ends screw onto the fitting you have, and thus through your fitting reduce flow into the turbo. Im terrible at explaining myself.....ok, try again. Is your fitting basically a -4AN fitting with a smaller hole through it making it a -3AN hole.
Sorry im an idiot
I could be wrong, but doesnt it go like this:
3AN - 3/16"
4AN- 4/16" or 1/4"
Here dude I got an idea...I got a 4an hose end, and a 3an piece. Il see if it screw on for ya
Edit- nope, the 3an is a little to small for the 4an hose end.
[Modified by B18EG6, 7:13 PM 1/18/2003]
3AN - 3/16"
4AN- 4/16" or 1/4"
Re: Where can i find a oil inlet flange like this?*pic* (B18EG6)
3AN - 3/16"
4AN- 4/16" or 1/4"
3AN - 3/16"
4AN- 4/16" or 1/4"
Correct. Ill take a pic or two if you want confirmation. But yes, the threaded sides are jussssst barely off. (doy...i guess 1/6" off)
Dan: ooh yes, they're totally different, the -3 and -4 are different in thread size..
hmm, I'd get like a -4 male to -3 female union, so you'll reduce oil press to the turbo...
Re: Where can i find a oil inlet flange like this?*pic* (phresh_5)
pjr710
08-17-2007 04:33 PM
b18cya
02-19-2003 10:50 PM
