Apex'i AFC question...
Ok, I have a friend who is finishing up his turbo on his car...but for fuel management he wants to run the hack...
I advised him to save for a hondata, but what can ya do...anyway he asked me how much boost you can run with it...didnt exactly know what to tell him
So, I guess my question is for those of you who are running the hack, how much boost are you efficiently/successfully running?
TIA
Kevin
TIA
Kevin
if you go above i believe 12 or 13, you'll throw a CEL, because you can only trick your ECU so much. If you go w/450, set back around -40%. I suppose you could run a missing link if you wanted more boost than that. Search the boards. There's PLENTY on the hack.
I just talked to Tony at Jotech this morning (Tony1), You can sucsessfully run a Afc hack with low boost after (i believe 8-9 you start having problems. You must run 440cc also. But it's mainly for low boost.
so, next thing he wants to know...
if he installs a vafc now on a non-vtec, can the vtec control just not be used? he wants to do a ls/vtec eventually and i guess it would be smart cuz it would save him money in the long run...so is that an option?
