Does Advancing the Ignition Cause a Temperature Rise?
Old Jan 16, 2003 | 05:11 AM
7rrivera7's Avatar
Default Does Advancing the Ignition Cause a Temperature Rise?
I'm playing with the ignition tables of my Zdyne Gold ECU because the B16 program that comes with it is very conservative. My car is running much stronger now that I have advanced the ignition within the tables but it seems to be running hotter. The water temps aren't rising but I sort of sense the engine is hotter.
Is this normal and can I damage the engine? I cannot hear it detonating.
Thanks!
Old Jan 16, 2003 | 06:04 AM
Desslok's Avatar
Default Re: Does Advancing the Ignition Cause a Temperature Rise? (7rrivera7)
Advancing the timing will cause it to run leaner, thus hotter, so you are correct. Running higher octane fuel, bumping up fuel pressure, using toluene, etc can help keep it from detonating.
Old Jan 16, 2003 | 10:38 AM
Steve91's Avatar
Acutally I hear the opposite may times. Retarding the timing tends to cause the motor to run hot .
Old Jan 16, 2003 | 10:41 AM
337 GTI 1.8t's Avatar
Default Re: Does Advancing the Ignition Cause a Temperature Rise? (sp)
retarding the ignition will cause it to run hotter...keep in mind, advancing could cause it to detonate, which is the hottest of them all.
[Modified by GTI 1.8t, 7:41 PM 1/16/2003]
Old Jan 16, 2003 | 10:42 AM
Desslok's Avatar
Default Re: Does Advancing the Ignition Cause a Temperature Rise? (Steve91)
Retarding the timing will cause it to run richer, thus running cooler. It's easy to show with a 4 gas analyzer, just check the NOX and make adjustments.
Old Jan 16, 2003 | 01:51 PM
tinkerbell's Avatar
rich = cooler
lean = hotter
t..
TB123
Engine Management and Tuning
Dec 30, 2013 08:34 PM
Mase
Nov 16, 2011 04:19 PM
See Are X
Aug 4, 2004 09:21 AM
Mantis88ls
May 14, 2004 05:37 AM
_Endless_
Aug 7, 2002 10:49 AM
