rockford HE2 12" subs, opinions needed
Old Jan 10, 2003 | 10:58 PM
whtrice01gsr's Avatar
Default rockford HE2 12" subs, opinions needed
ok i can get a screamin deal on these subs. they can handle 400 RMS watts and i plan to install them in my new tacoma. they retail for $199.99 but im getting 2 (brand new, sealed in box) for that price. i was hoping some of u audiophiles could give me opinions on this sub. ill b running 2 of these w/ the rockford punch 700s amp. it produces 700 RMS watts X1 bridged. will this b a good setup? thanks
Old Jan 10, 2003 | 11:12 PM
philly-O's Avatar
Default Re: rockford HE2 12" subs, opinions needed (whtrice01gsr)
yes it is a very well matched pair.
Old Jan 11, 2003 | 02:03 AM
Default Re: rockford HE2 12" subs, opinions needed (peichie)
thanks for the reply, but could u b more specific. do u have any experience w/ these subs? also im going to put them in a sealed enclosure, is that the best u think? i dont like bandpass boxes. also will these pound pretty hard? i dont need a ton of bass, mainly want it crisp and clean but want to hit those lows when i want, thanks again
Old Jan 11, 2003 | 09:36 AM
RA217252's Avatar
for $261.00 you can get two elemental designs e15k's will sound much better and you can prolly run that amp for them
here check the link you will not be dissatisfied
http://www.edesignaudio.com/miva/mer...egory_Code=CSP
Old Jan 11, 2003 | 02:13 PM
Default Re: rockford HE2 12" subs, opinions needed (sheehan024)
why r those better then the rockford's? i didnt c any specs for em.
Old Jan 11, 2003 | 04:08 PM
philly-O's Avatar
put the rockford subs in a sealed box, 1 cubic foot per sub.
Old Jan 11, 2003 | 05:37 PM
GSteg's Avatar
http://edesignaudio.com/ep/kseries.htm
i'd take the k-series over the rockfords anyday. i have the E15K sitting right next to me (well not that close to the monitor will go funky again..). built quality is better than the rockfords imo. the k-series has something the rockfords don't have. sound quality!!<---being sarcastic
u won't be dissappointed with these. (unless you have VERY high expectation.)
Old Jan 12, 2003 | 08:48 AM
johann's Avatar
i was running two he2 12" subs in a sealed box at 500 watts rms. one caught on fire and the other one blew up. actually thinking about it every rockford fosgate product i bought blew up, two decks, one amp, and two sub. i will never buy rockford again
Old Jan 12, 2003 | 09:18 AM
RA217252's Avatar
Default Re: rockford HE2 12" subs, opinions needed (johann)
GSteg: for knowing your ****
Old Jan 12, 2003 | 10:15 AM
Bbasso's Avatar
I have two Fosgate 12 in a sealed box for almost 3 years and NOT one problem and I have them at 2ohm and 250watt per speaker.
They kick *** and there are a few people on here who have heard them and will say they sound good.
If you have problems with any speaker or amp it is most likely due to the install and not the peice.
Old Jan 12, 2003 | 08:19 PM
101998's Avatar
Default Re: rockford HE2 12" subs, opinions needed (Bbasso)
I run 3 HE2 10" w/ a 700s and a 500x, I love it. Had to buy hella dynomat to stop it from rattling, but it hits very hard and I've had this setup for about 5 months w/ no problems.
Old Jan 13, 2003 | 08:40 AM
johann's Avatar
you can't drop two dvc down to two ohms, its either one ore four
Old Jan 13, 2003 | 10:38 AM
thanks for all the great replies guys i picked up 2 12" HE2's on sat and going to run the 700s to em. i just hope this is enough power for em??? also not sure on a box yet
Old Jan 13, 2003 | 10:53 AM
101998's Avatar
yes you can. I have my 700s pushing 2 dvc's wired for 2 ohms.
Old Jan 13, 2003 | 11:19 AM
Default Re: rockford HE2 12" subs, opinions needed (audiobahnman)
audiobahnman- do u think the 700s bridged will run 2 HE2 12"s ok???
Old Jan 13, 2003 | 11:56 AM
philly-O's Avatar
very much so
Old Jan 13, 2003 | 08:04 PM
101998's Avatar
Ok? That will slam, like I said I run 3 he2 10's, two powered by a 700s the other by the 500x. The current joke for my car is to bring earmuffs.
Old Jan 14, 2003 | 07:45 AM
vehic_illu's Avatar
Running mulitple subs off of different sized amps is really not that good of an idea. Your not using your woofers very effeciantly and it could be a lot louder if you used one big amp to power them. Due to power distribution and actual power of the amps, you may be cancelling out soundwaves that could make the car even louder!! I have no doubt that those woofers are rockin, they are a good product no matter what others say. Rockford woofers will not blow if you know how to treat them well. They jam, but for a lot less time if you tune them improperly.
Old Jan 14, 2003 | 10:19 PM
incubus's Avatar
explain to me how you do this, because i would love to know.
the he2's are only offered in dual 4 ohm and the 700s is a 2 channel amp so you are mistaken.
if you had a 700x it would be possible to run them in a 2ohm load because it is a 4 channel amp.
Old Jan 15, 2003 | 09:01 PM
Bbasso's Avatar
let me rephrase that..
each 12 is at 2ohm and each 12 has 250 watts. I only have two 12s and a 500watt amp at 4ohms but knocked to 2ohms per speaker- so It has a little more then 250 per 12...
Is that to everyones satisfactory?
Old Jan 16, 2003 | 02:34 PM
GSteg's Avatar
(2) dual 2ohm can be wired to 2ohm
Old Jan 16, 2003 | 06:15 PM
johann's Avatar
Default Re: rockford HE2 12" subs, opinions needed (GSteg)
are he2 dual 2ohm
Old Jan 17, 2003 | 12:30 PM
cruckssi's Avatar
I used to have 1 he2 12" running 250 rms to it and it badly needed more. I don't know how 350 will sound, but I would think that with 500rms the speaker could get loud. One thing i don't like about rockford it the "boomy" sound that they have. Thats why I got rid of mine. And whoever said go with eD, I agree. Great c/s, the best I have ever seen, and a 3 year warrenty.
Old Jan 17, 2003 | 10:52 PM
JOMO
Guest
Posts: n/a
not all the time, if alot of people have problems with fosgate then it cant be a coinsidence, ive heard about <U>ALOT</U> of problems with rockford, especially their newer stuff, my friend is a proffesional installer and he warned me against their products, you can do much, much better than these
WILD_WILL
Audio / Security / Video
Aug 13, 2008 10:54 AM
Thapromisedkid1
Jan 29, 2007 04:52 PM
97dc4 0614
11
Oct 22, 2006 10:03 PM
S2Kstuntin
Mar 14, 2006 05:17 PM
ACR
38
Jun 9, 2003 04:12 PM
