Need Help! V-tec Problem
Old Jan 9, 2003 | 05:23 PM
DocV's Avatar
Default Need Help! V-tec Problem
Hey H-T,
I have a 2k1 GS-R and today my V-tec did not kick in at all. I check the oil and it's not low, so what else could be the problem. The car only has 20k on it and the mods are I/h/e w/ a test pipe. Any ideas? Thanks
Old Jan 9, 2003 | 05:28 PM
bus stop's Avatar
Default Re: Need Help! V-tec Problem (VtecNit2k1)
Did your motor warm enough when you take the rpm up into the vtec range ?
Old Jan 9, 2003 | 05:32 PM
sslude's Avatar
Default Re: Need Help! V-tec Problem (WhosITR)
yea, warm up your car first.
Old Jan 9, 2003 | 07:03 PM
vtec.dc2's Avatar
Hey H-T,
1. check oil
2. warm up the car, once it is, drive it easy for the first 2-5miles
Old Jan 10, 2003 | 06:44 AM
DocV's Avatar
Default Re: Need Help! V-tec Problem (vtec.dc2)
Like i said i check the oil and the car was warmed up. I guess i gotta drop this thing off to the dealer
Old Jan 10, 2003 | 09:13 AM
ITR#00-1077's Avatar
There is a way to check to see if your VTEC is working or not... for the 94-95 GSRs... drive the car in 1st gear and stay in VTEC at around 6000 rpm (I know the GSR's VTEC point is around 4400-5000rpm) or so and let the car ride like that for about 7 seconds (if I remember correctly) and if the CEL blinks a number of times then you have something wrong with your VTEC/solenoid....
Sorry if this info is wrong, but I remember doing this a while back on my 94 GSR.. and this is totally off from memory....
Old Jan 10, 2003 | 05:47 PM
DocV's Avatar
Default Re: Need Help! V-tec Problem (ITR#00-1077)
Don't worry it was nothing major it was my Vechicle speed sensor. It got some salt and **** from Sunday's snow storm in DE. My car is so low I guess that it got caught up in there. Thanks for you guys advice though.
Old Jan 10, 2003 | 05:52 PM
Fuminsho's Avatar
Man am I taking you to seriously or did you say you got **** up there as well as salt?!
**** from what?
Any whoo, glad that it was nothing major...
greddy13
Oct 24, 2005 10:40 AM
H22A_HB
Oct 22, 2004 11:10 PM
BlckSI
Aug 29, 2003 06:48 PM
goforbroke
Feb 24, 2003 04:47 PM
DocV
Jan 10, 2003 06:58 PM
