Anyone ever do a head swap on a 95 cx?
Old Jan 8, 2003 | 03:04 PM
civicmatt's Avatar
Default Anyone ever do a head swap on a 95 cx?
I want to know if a 95 cx has 8 or 16 valve indents. Also, has anyone done a 16v head swap on pistons with only 8 indents? Thanks.
Old Jan 8, 2003 | 03:06 PM
H22Ain97ITR's Avatar
Default Re: Anyone ever do a head swap on a 95 cx? (civicmatt)
WHY?
Old Jan 8, 2003 | 03:09 PM
SpooN Man's Avatar
You could just clay the motor.
Claying the motor will insure that you have sufficient clearance between the head, pistons and valves (0.035").
here is a link to how to do it
http://www.c-speedracing.com/howto/claymotor/clay.php
Old Jan 8, 2003 | 03:40 PM
civicmatt's Avatar
Default Re: Anyone ever do a head swap on a 95 cx? (SpooN Man)
Ha, ha! WHY? Cx's are slow. Thanks for the reply though.
I've heard about claying the motor, but how is it done? Is taht something I would have to take to a shop, or can it be done at home? does anyone know if a head swap would work on a cx?
Old Jan 8, 2003 | 05:03 PM
AztecRacer's Avatar
Did one one time, did not have the money to do a full swap. Put a d16a6 head on the Cx block, a d16z6 intake and a header on it also. Cx intake and exhaust manifold are really to small for the d16a6 head. Computer had a tuff time with the new parts put on, rev limiter is reached really quick...lol. Do a D16Z6 swap with the trans also and you won't be dissapointed. Good Luck.
Old Jan 8, 2003 | 05:04 PM
redcxhatch's Avatar
Default Re: Anyone ever do a head swap on a 95 cx? (AztecRacer)
Just buy a D15B7 swap for like $100.
Old Jan 8, 2003 | 05:13 PM
tominos's Avatar
http://www.c-speedracing.com/howto/claymotor/clay.php check that out, how to on claying your motor.
Old Jan 8, 2003 | 10:43 PM
oldskool_rex's Avatar
don't listen to these homos......I put a Z6 VTEC head on my 95 CX motor (which has the same paitons in it as a DX BTW, having 4 reliefs in each piston).
So far my car is faster than a 99-00 Si with I/H/E, and a 98 Civic Ex with an LS motor. I still have that puny stock cat too, as well as the stock intake.
The CX bottom end is perfect for fitting a VTEC head. Compression is over 10:1. The car is quick!
yaleforizzle
Jun 28, 2004 01:03 PM
92CIVICCX
Mar 25, 2004 06:37 AM
civicmatt
Jul 30, 2002 07:05 PM
The_Brian
11
Jun 17, 2002 11:29 AM
