Anyone ever do a head swap on a 95 cx?
I want to know if a 95 cx has 8 or 16 valve indents. Also, has anyone done a 16v head swap on pistons with only 8 indents? Thanks.
1 Post
Re: Anyone ever do a head swap on a 95 cx? (civicmatt)
You could just clay the motor.
Claying the motor will insure that you have sufficient clearance between the head, pistons and valves (0.035").
here is a link to how to do it
http://www.c-speedracing.com/howto/claymotor/clay.php
Re: Anyone ever do a head swap on a 95 cx? (SpooN Man)
Ha, ha! WHY? Cx's are slow. Thanks for the reply though.
I've heard about claying the motor, but how is it done? Is taht something I would have to take to a shop, or can it be done at home? does anyone know if a head swap would work on a cx?
Did one one time, did not have the money to do a full swap. Put a d16a6 head on the Cx block, a d16z6 intake and a header on it also. Cx intake and exhaust manifold are really to small for the d16a6 head. Computer had a tuff time with the new parts put on, rev limiter is reached really quick...lol. Do a D16Z6 swap with the trans also and you won't be dissapointed. Good Luck.
http://www.c-speedracing.com/howto/claymotor/clay.php check that out, how to on claying your motor.
don't listen to these homos......I put a Z6 VTEC head on my 95 CX motor (which has the same paitons in it as a DX BTW, having 4 reliefs in each piston).
So far my car is faster than a 99-00 Si with I/H/E, and a 98 Civic Ex with an LS motor. I still have that puny stock cat too, as well as the stock intake.
The CX bottom end is perfect for fitting a VTEC head. Compression is over 10:1. The car is quick!
civicmatt
07-30-2002 07:05 PM
