Why does the JDM H22 motor produce more power than the USDM??
Old Jan 5, 2003 | 01:46 PM
AndyD's Avatar
Default Why does the JDM H22 motor produce more power than the USDM??
I was just curious what is different about the JDM from the USDM??
Thanks
Old Jan 5, 2003 | 01:52 PM
2000TypeSh's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (AndyD)
Higher compression.
Old Jan 5, 2003 | 01:53 PM
2000TypeSh's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (2000TypeSh)
Oh yeah, are you talking about the type S motor or not?
Old Jan 5, 2003 | 01:55 PM
AndyD's Avatar
No, just the regular JDM h22a1.
Oh, so how was the compression changed?? Different pistons??
Old Jan 5, 2003 | 02:14 PM
aklucsarits's Avatar
New User
US: 10.0:1 compression
Japan: 10.6:1 compression
Andrew
Old Jan 5, 2003 | 02:49 PM
Mike95lude's Avatar
Yep, pistons. Also, the JDM motor is referred to only as the "H22A" with no numerical prefix after it.
Old Jan 5, 2003 | 09:34 PM
Jago's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (Mike95lude)
and it's a great motor.
Old Jan 5, 2003 | 09:54 PM
sslude's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (Jago)
and becasue of restrictions. USA has stricter laws about pollution.
Old Jan 5, 2003 | 10:09 PM
visual's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (sslude)
true, but specifically CA emission laws.
satan_srv's Avatar
like already mentioned different pistons and likely a better tuned ecu to use the extra compression better.
Old Jan 6, 2003 | 04:10 AM
KGAccord's Avatar
QUOTE]and becasue of restrictions. USA has stricter laws about pollution.[/QUOTE]
JDM H22s will pass emissions and remember why we get so many with 30-40K on them, cause Japan taxes the **** out of high mileage motors for 2 reason: keep auto industry going and emissions.
Old Jan 6, 2003 | 04:30 AM
gsrhatch530's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (KGAccord)
Will it pass california emmisions?
Old Jan 6, 2003 | 04:43 AM
New User
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (gsrhatch530)
FWIW, my bone-stock 1993 Prelude VTEC (US model) used to just barely pass Pennsylvania emissions every year. From what I understand, CA emissions have even lower limits. That car had 27k mi to 69k mi on it when I owned it. The H22A is not the cleanest running engine to begin with...
Andrew
Old Jan 6, 2003 | 04:55 AM
KGAccord's Avatar
Default Re: Why does the JDM H22 motor produce more power than the USDM?? (aklucsarits)
A person who got his JDM H22 swapped at the same shop as me passed emissions in MA with a new oem lude cat. Luckily NH has no emissions.
Old Jan 6, 2003 | 06:02 AM
HotWheelz's Avatar
different cam profiles:
Stock Specs from H22 Type SH Int-275 mid Exh-275 mid Int-225 mid Exh-227 mid Int-.448 mid Exh-.415 mid
Stock Specs from H22 JDM-spec Int-271 mid Exh-277 mid Int-224 mid Exh-224 mid Int-.446 mid Exh-.415 mid
10.6 compression ratio,
and ECU tunning...
other than that all similar
Old Jan 6, 2003 | 07:07 AM
rjr162's Avatar
Correction: Only certain areas of PA have emmisions! (mostly in the pittsburgh and philly areas)
92SiBlu
17
Dec 15, 2004 08:23 AM
simon98h22
Dec 9, 2004 05:07 AM
tylek17
Apr 18, 2004 05:48 PM
EgSick
Nov 5, 2002 08:46 AM
IgniteTeg
Oct 30, 2002 12:34 PM
