T25/14b oil FEED setups 3-An ss braided CHEAP CHEAP !!! look !! others look too
heres a list of the stuff i got from AMstreetrod.com
heres a fitting that i think MOST ppl dont know about , works with T25 and 14B cuz it comes in a package of two and i used it on my buddies 14B and my T25.
Brake Adapter Qty. 2 per pkg.
591932 3 AN to 7/16-24 I.F.* Steel $9.57
* Inverted Flare
63010140 Speed-FLex Hose 3-An- $19.36
( ss braided oil feed line)
961603 Steel Adapter's pipe to AN straight 3, 1/8 $1.55
( off the block/Tee for oil feed and pressure switch.
The speedflex hose already has straight swivel seal fittings on it, so no need to put the lines together.
i highly recommend the speedflex hose becuase it handles high temps and pressures and is VERY VERY cheap and cost effective !!
* Inverted Flare
I always thought the 14b oil feed fitting was different than the t25?
I was just shopping for some good oil feed setups.
